Missfire #1 cylinder help engine 276!!
With Xentry and a 4 channels pico automotive scope + 2 low current clamps and some hard work because of your airbox, you can see which one went "bad" first, Ignition or Fueling.
I don't envy M276.9 3.5NA air box when doing troubleshooting ignition, fuel injectors and engine breathing.
It is so pain in the azz by design for us to troubleshoot ( based on photos if for me ), as no M276.9 was introduced in my local market, they jump to M276.8 3.0 Turbo from M272 3.5 or 3.0
For my country, in 2009, engine with higher than 3.0 liter displacement, there will be luxury sales tax like 40% or so , hence that strategy of engine choice MB took.
Mine is easier M276.8 3.0 Turbo as my air box is purely airbox and not part of intake manifold like M276.9 3.5NA
I feel your pain
M276.9 being a MAF engine, the airbox vacuum hoses & PCV hoses and if one get loose ENOUGH, it will cause bad idle and distract you from your initial troubleshooting
Mine because of a turbo version, uses MAP ( speed density as US tech likes to call ).
I feel your pain
Received 4,647 Likes
Audit/test them first before deciding anything.
I am sure you have DC current clamp right ?
Use your Xentry to monitor B95 Battery Sensor, or your Instrument Cluster can do that too. Better use Xentry.
Get a DMM as a volt meter to monitor at F32 copper bar, that small bar where you charge the battery.
The current clamp will read Gross amperage out of the alternator, before power consumers consume them and surplus is given to battery.
B95 sensor or battery, gets NET power or sometimes battery MUST give power to F32 ( devices ) when and if the dumb-azz yoyo voltage at alternator falls below 12.6V causing a deficit.
B95 will show positive or negative amperage and the actual voltage at battery terminals.
Load the car with HVAC maximum blower speed and heater core activated to heat up evaporator and hence run compressor more and the radiator fan faster.
High beam ON, if you have electrical based heater on the car, turn them all.
Do not play with your electric power steering for the time being...YET, this is the biggest sudden power sucker of them all.
Having engine at proper operating temperature would be good as the hotter the engine bay gets, the possibility of electrical gremlins appearing is higher.
Share your findings.
Next test, remove the single LIN cable connector to your alternator and do the same test.
Removing LIN will make alternator revert back to its original setting without engine ECU intervention, expect to see awesome 13.6 to 13.9V all the time and very nice precise low amperage
charging at B95 sensor when and if the battery is already starting to be fully charged.
Now play with your ELECTRIC power steering, lock to lock L to R but do it slowly and not too fast.
Here you can see how fast a non ECU intervention alternator response to the EPS demand.
By then you can tell if your alternator can actually supply enough current/power or not ?
I think your alternator is easy 180A, mine is 200A and I am not a winter car with any electric heaters except the rear windshield defroster..
The voltage reading at F32 copper bar is to make sure there is no significant voltage drop between your F32 to Battery.
The ground of your DMM for F32 voltage reading , use the engine lift hook. This way we can also see if the un-documented W-TF ground cable from car under carriage to the
engine's block near starter motor is decent or not.
ADD : You are probably in winter now, so your radiator fan may not run fast. Use your Xentry to maximize M4/7 radiator fan, to 90% ( maximum ) when your engine already hot.
This one is 600 - 800 watts of power sucker.
After all these test, cleaning your car grounds ( a few important ones) connection is a must do, after all the car is 10 years old at least...right ?
Have fun.
Have fun.
The following 3 users liked this post by S-Prihadi:
Received 1,917 Likes
JettaRed, Without a doubt, a bad battery will kill the alternator as the battery is putting a large constant current draw the alternator must produce. I liked your checklist above. The flickering dome lights indicated to me an alternator - vol at age regulator issue.
My son had a 1998 Red Jetta. We pulled the engine five times. He had the car for seven years and won a second place at Water Fest. He learned a lot about working on cars with that car and he and I spent countless and precious father-son hours under his red Jetta. Whenever I see a red Jetta, Imthink back to those days.
OK, back to this thread.
Have fun.
Have fun.
So far I did test the voltage on the cooper bar and rest of the ports on the F32 and wile engine running I have 14.4 V I use Matco voltmeter.
i will do your advice and use clamp and check the amps and also I will check the undercarriage ground point.
ill let you know the findings
keep it in mind I work after hours on this car
Nobody wants to touch it anymore I am trying to save it from junking it (it’s nice car overall)
S-Prihadi (02-20-2024)
Maybe MS Visio for your Birthday
@S-Prihadi love your artwork, but have you ever considered MS Visio?
#32
#34
Did you resolve it?
CaliBenzDriver (02-19-2024)
#40
Everything looked good until that last pic. It does appear you are running a little rich on the right bank, but not outside permissible limits (0.782v). Cylinder 1 is right bank.
Maybe someone smarter than I can explain the high misfire count.
MakUsa (02-19-2024)
#42
Its normal to do that, as long as you add ground wire from engine block to the s-plugs metal thread to let it fire to its L tip and not to send "Zeus" to other components...
#43
OK, for the time being alternator seems fine.
Xentry detected misfire on cylinder 1.
Since cylinder 1 belongs to Bank 1 or Right Bank , you see a bit rich Lambda at 0.923.
Mild rich.
The RIGHT / BANK 1 rear narrow band oxygen sensor after CAT also confirms a rich condition.
But for rear oxygen sensor, you need to graph it overtime , a single look short duration does not tell the whole story as this sensor is for CAT and not for engine per se.
It is actually easier to understand fuel mix with AFR value than a Lambda value.
If we use 0.92 Lambda, we see 13.52 AFR
So 1 part fuel only get 13.52 air, short of the target stoich of 14.7 air.
So lack of air it is.....if based on how the front / upstream wideband oxygen sensor is seeing.
Let say we have bad injector spraying more fuel than intended due to a mechanical problem, would the result be also RICH, .......yes.
3 things can cause a misfire.
AA. Injector - fueling, can be spray pattern, spray quanity, delayed spray timing
BB. COP - Weak firing due to few reasons.
CC. Breathing air into the cylinder and its timing.
What Mak did :
01. Injector was swap with new one. I hope it is coded to tell ECU the "metering & inductance" value of the new injector. That 6-8 or so digits on the injectors.
Have you coded the new injector ?
and others below.....
VVT issue is not likely as only cylinder 1 is the issue.
Mak,
Did you check the condition of the hydraulic lifter tappet ( #60) and roller cam follower (#50) of intake and exhaust valves cylinder 1 ? and the intake and exhaust lobe on the camshafts of Cylinder 1 ?
If item #60 goes bad, the valve opening can be bad or not open enough.
Even on manual adjusted valve clearance engine, if left un-check , this can cause misfire.
Your M276.9 of 145,000 miles is a lot of miles .
I think unless the #60 is really bad, it might not show when visually inspected because we can't tell if it leaks enough oil to collapsed itself and be out of spec.
In-cylinder pressure waveform testing can show breathing problem in a cylinder.
This is a 2 hour long video but its a good watch if you want to see what In-cylinder pressure waveform testing can do without engine tear down and in fact sometime the only way to see minor issues where we need
a running engine to see the actual fault occuring.
If you want to invest in the pressure transducers, no need the super expensive Pico WPS500. Go for Rotkee ones.
https://store.rotkee.com/en/automoti...tic-equipment/
Get these :
https://store.rotkee.com/en/pds-pres...ransducer.html <<< This is equal to the FIRST LOOK sensor the 2 hour video is using. It will read overall intake manifold pressure swing.
https://store.rotkee.com/en/lx6-coil-on-plug-probe.html
https://store.rotkee.com/en/ps16-in-...ol-engine.html <<< Having 2 of this is also good, you can use it for intake manifold and exhaust too, aside from in-cylinder.
Choose suitable adapters for it.
The lx6-coil-on-plug-probe can show the combustion pattern on all your cylinders at the same time, so easy to compare a bad one from the good ones.
I have a few different COP probes but not yet the Rotkee ones. Would love to get them too soon.
Good luck with your troubleshooting.
Mild rich.
What Mak did :
Mak,
Get these :
pierrejoliat (02-21-2024)
#45
If say inlet valve never opened enough due to hydraulic lifter issue and let say only 50% of regular air intake happen, your testing of compression using mechanical gauge
which has check valve and is reading peak pressure only, does not tell the story per 1 event of compression in a full picture of the 720 degrees crank.
The manual gauge compression test is cranking for a few seconds and that cylinder get a few compression events, so that is accumulated peak pressure-s and held in place by check valve.
200 RPM crankshaft cranking speed typical of a starter, for say 3 seconds is approx 4.5 compression events per cylinder.
So your compression testing is by-product of that many air intake events being compressed to represent a single reading. I hope that make sense.
In-cylinder waveform engine cranking only or engine idling and with fast throttle when using scope and pressure transducer,
we can see per 1 compression event and hundreds of them. Exactly as how a combustion should happen, 1 event at a time.
Try and use Xentry Compression Test under N3/10 engine computer.
See how much slower or faster is cylinder 1 compared to other cylinders.
I think Xentry uses averaging, because we need like 7 seconds cranking before it is completed.
The averaging would still show some differences...I am hoping.
At least do the Xentry compression test twice, to be certain.
#46
Maybe a leak-down test for cylinder 1 is in order. As @S-Prihadi said, a mechanical compression test is showing peak values. A lead-down will show whether the cylinder chamber is tight or not. Bad rings, scored cylinder walls, cracked head, torn/blown head gasket, etc. may not show with a mechanical compression test if they are minor deformities, but would certainly cause a leak-down test to fail.
Have you scoped the cylinder?
#47
If the valve is broken off at its sealing side and not sealing, YES, you loose compression tested using mechanical gauge.
And also I will do leak down test and post the results.
Thanks guys
#48
I will post the results
#49
#50
