The rear wiper has forgotten its position. E220 2015. Kombi.
The rear wiper has forgotten its position. Every time I start the car it starts driving and stops. All of a sudden in the middle of it all. Can it be reset. ?
Gently manually move it to the parallel position. See if that helps. If not, you can loosen the nut holding the wiper arm to the motor and move it parallel and tighten the nut in the correct position.
CaliBenzDriver (02-27-2024)
it has returned by itself to the correct position. And drive as it should be 3-4sec. but it became incorrect again after a day. When you turn it on, it should run every 3-4 seconds. but it runs constantly and stops in the wrong places. what could it be?
