Which M272 engine type uses this unknown Intake Manifold Tumbler/Flap system ?
I am curious because I can't find it in EPC even though I tracked all the way to W203 era.
This is what I have seen as M272 intake manifold design.
3 of vacuum actuators I labeled 4A to 4C and two of internal links I labeled 2A and 2B
Technical version image
I then look at WIS for W212 with M272
What Alien Intake Manifold is this ? Single link only and also only 2 vacuum actuators.
I have traced the very rare one, single link and single vacuum actuator, which is for the SUPER RARE M272 with DIRECT INJECTION.
I am simply blown away by alien intake manifold.
Anyone can share your wisdom on this older engine ?
trigital (09-07-2024)
The last image I posted is the rare CGI ( direct injection ) version intake manifold.
I wish there is a proper wiki on the 3 last digits meaning of our engines after the model number.
I have the list from EPC/WIS but not their actual difference
M272.??? CGI has 4 versions.
DE is Direct Injection DELA is Direct Injection with Turbo.
S-Prihadi (09-07-2024)
The first picture is the one from all M272, the second one is from M273 engines and the last one is mislabeled because it belongs to M113/M112 engines. 19 year specializing in Mercedes Benz, I don't need to look up anything. I just see it and know what engine it goes to. There is a plastic manifold available from the high output rated M272 that can be retrofitted which uses the throttle body from the M273 (bigger).
S-Prihadi (09-14-2024)
