Sponsored by: CARiD
TPMS Programming
Old Oct 6, 2024 | 05:35 PM
Davery's Avatar
2012 E550 Cabriolet 2011 VW Eos 1985 Pininfarina Spider
TPMS Programming
I just had new wheels installed and I believe the installer damaged a valve stem and I am losing air, but he is not taking responsibility. I found a new aftermarket 433 Mhz TPM sensor locally that I can get today. It does not specifically say it is for a Mercedes. Could I use this? Would this need to be programmed?
Old Oct 6, 2024 | 05:44 PM
JettaRed's Avatar
Veteran: Army
It'll probably work without any programming. When I bought winter tire sets from TireRack with sensors they worked immediately.
Old Oct 6, 2024 | 06:46 PM
pierrejoliat's Avatar
24 GLS580 '23 E450 4matic 12 E350 4Matic
If it runs at 433MHZ and is pre-programmed for KXS033 it should sinc up in 5-10 miles of driving,
