Mileage from DPF not in accordance with tacho
If difference goes say a few thousand KM, maybe someone mess with the data.
Is the paint pristine, I.e. did the car have a wrap on it from the beginning?
I don’t know what country you are in but in Germany taxis have the wrap that hides the true car color under it. Then wrap is removed when taxi service ends.
If it was a taxi you may be able to see the suction cup impression on the paint where the taxi sign was on the roof. Sometimes it leaves an imprint in paint thru the wrap as the suction cup is very close in the same place at all times.
The exact 100K more mileage into the DPF history is more likely a wrong manipulation of a scanner - wrongly "reset data from DPF". The mileage manipulation on MB is very easy to be discovered.
