Sponsored by: CARiD
Vin says extra oil option. 1200ml.
Old Apr 6, 2025 | 03:57 PM
Antoniio's Avatar
w212 e350 CDI BLUETEC 4 MATIC STATE
9.6 or 9.3
Old Apr 6, 2025 | 04:09 PM
W205C43PFL's Avatar
Originally Posted by Antoniio
9.6 or 9.3
Put your VIN in a decoder like lastvin or mb.vin, look for engine oil offset amount, post it here, forum members will calculate it for you.
Old Apr 6, 2025 | 04:25 PM
Antoniio's Avatar
The mine 8 liters + 1,3 liters. Total 9,3 liters with filter.
Old Apr 6, 2025 | 04:37 PM
W205C43PFL's Avatar
Better safe than sorry, I do not recommend risking having too much engine oil, not saying your datacard is wrong but better safe than sorry.
How much engine oil is shown on the dipstick, at operating temperature and checking using the method instructed in the operator's manual? Depending on the vehicle, it is checked differently, for example, just as an example, some vehicles: it is 5 minutes after vehicle is off at leveled surface at operating temperature, or you could also check first thing in the morning. Leveled surface is very important, in my case it was close to minimum if following the operator's manual, adding the offset amount brings it back up to where it really should be.
This was true for many of my engine oil changes, I always DIY, again every MB is different even with same engine hence why they put this oil offset amount in the datacard.
Old Apr 6, 2025 | 08:50 PM
JettaRed's Avatar
Veteran: Army
Yes it is that amount plus the offset amount, usually when I just go by what is mentioned in the operator's manual, for example my 2017 c 43, it is 6.5L and my data card shows 1000ml, if I do 6.5L, every time I check it, it is below the middle mark and very close to min mark. This is checking using the method following what the operator's manual instructed. On the safe side, I do 7.2-7.3L which leaves room before the max mark, after all, too much engine oil can be catastrophic.
True, but too much means WAY TOO MUCH. Being a little over the max line I would not consider as too much.
Still, it is curious that we both have the M276 turbo engines, but my offset is 600 ml and yours is 1000 ml. What is your engine's hp rating? Stock, mine is 329 hp. My capacity doesn't change with a tune.
Old Apr 6, 2025 | 09:03 PM
W205C43PFL's Avatar
Thanks forum member JettaRed : ) That is a relief. I want to be careful with my recommendations when it comes to these things as I really don't want to mess up someone's engine so your expert opinion you provided is much appreciated! I am glad to hear that you have to be a lot over to have issues. I guess for example, the oil touching the metal part of the dipstick?
To answer your question, horsepower is 362, the facelift is 385. Same torque though for both. 384.
I am not sure if the facelift has a bigger turbo, I do know the E 43 has a bigger turbo (I mean, that is what I heard)
Old Apr 8, 2025 | 11:08 AM
  #32
JettaRed's Avatar
Veteran: Army
Here is an interesting video on the effects of over-filling the oil.
Old Apr 8, 2025 | 12:18 PM
  #33
Mercmiester's Avatar
C300 15
Mine is 1200 ml offset. So how much? I only have 7 liters in rn
Old Apr 8, 2025 | 01:05 PM
  #34
W205C43PFL's Avatar
https://youtu.be/VaTbfvzNbxQ?si=KSF4JhuYXCKzuSpw
Thanks, I actually saw this video before or maybe I have deja vu.
Old Apr 8, 2025 | 01:07 PM
  #35
W205C43PFL's Avatar
7 Liters should be good, give it the 200ml breathing room. The main question is, how does your dipstick look, at 7 liters, are you still below the middle part of the dipstick or slightly above, if slightly above, you may add some more. Try to not be as close at the full line as possible but forum member JettaRed confirmed with us even if slightly above full will not be an issue, don't worry. Obviously, the method of checking the dipstick also could affect the reading, tell us how do you check your oil.
Old Apr 8, 2025 | 02:43 PM
  #36
JettaRed's Avatar
Veteran: Army
I posted it before...
Old Apr 8, 2025 | 02:49 PM
  #37
W205C43PFL's Avatar
That explains it.
Old Apr 9, 2025 | 05:41 AM
  #38
C300 15
It was half way. After adding the last quarter it feels better.
Old Apr 9, 2025 | 07:38 AM
  #39
W205C43PFL's Avatar
