Sponsored by: CARiD
Q about shifting into Park when door opens or key is turned off.
Old Apr 20, 2025 | 11:04 AM
W205C43PFL's Avatar
Originally Posted by S-Prihadi
As promised, door openings at various speed above 10KM per hour.
I went out today, so I can do this simple test for u guys.
https://youtu.be/rVdW3ZrfVKs
Scary, you actually did that? Dang... for science?
Old Apr 20, 2025 | 11:05 AM
W205C43PFL's Avatar
Those arrows next to P I am sure is for automatic parking.
At low speed the car is scanning for parking spot.
https://youtu.be/hZQMEft-5sM
My car has this feature but I never use it.
Sorry for the confusion, I am talking about the arrows below the N R and D, That image I posted before was misleading.
Old Apr 20, 2025 | 11:08 AM
W205C43PFL's Avatar
Here is a much better image: https://cimg1.ibsrv.net/gimg/www.mbw...53c784ca79.jpg
notice the arrows pointing up on the left side of R, left side of N and right side of P? Those arrows won't appear if the condition doesn't meet to go into those gears.
Old Apr 20, 2025 | 11:09 AM
S-Prihadi's Avatar
It is not dangerous at all, unless I am doing 200 KM/H or higher and open the door.
As long as the road is nice straight and safe as in a paid highway( not narrow 2 way ) or quiet housing area, all good.
My eyes is on the road, only my camera is aimed to the right door.
Old Apr 20, 2025 | 11:18 AM
W205C43PFL's Avatar
Was worried about the wind when you open and blow the door open further than you wanted. Glad everything is all good!
Old Apr 20, 2025 | 11:19 AM
W205C43PFL's Avatar
I guess they also call that turbulence : )
Old Apr 20, 2025 | 11:20 AM
  #32
W205C43PFL's Avatar
Actually nevermind, that is an aircraft term but with the turbine vents in modern MBs, it might as well be an aircraft.
Old Apr 20, 2025 | 11:28 AM
  #33
S-Prihadi's Avatar
, the door would want to close by wind force actually for our typical door style.
But if I ABS locked the brake when door opened, maybe it will damage the hinge.
If this kind of Rolls Rocye door with hinge at B pillar, it is risky to open it up at speed
Old Apr 20, 2025 | 11:49 AM
  #34
W205C43PFL's Avatar
They are not called suicide doors for nothing.
Old Apr 20, 2025 | 05:23 PM
  #35
JettaRed's Avatar
Veteran: Army
Great! Now I know it is safe to open the door to pee while driving. It still splashes a bit.
Old Apr 20, 2025 | 05:35 PM
  #36
W205C43PFL's Avatar
I mean, I guess there are those times you really have to... um go... especially for long journeys.
Old Apr 20, 2025 | 06:52 PM
  #37
Dave Doolittle's Avatar
2013 E350
Thank you for doing that!
Old Apr 20, 2025 | 08:48 PM
  #38
ChuangTzu's Avatar
19 GLA45, 86 560SL, former: 14 E550 4Matic, 09 E350 4Matic, 83 240D manual, 78 450SLC, 81 500SLC
It's safe and allowable to open the door on a Cessna 172 at any speed the plane is capable of flying (up to around 187mph). They have the same feature where the wind wants to blow the door (mostly) shut, so it's actually quite difficult to open it more than a crack, but they unlatch on their own all the time.
If you lose some control surfaces, you can actually maneuver the plane a bit by using the doors....
Old Apr 20, 2025 | 10:32 PM
  #39
2013 E350
How would one parachute out in case of emergency if the doors only open a crack?
Old Apr 21, 2025 | 12:11 AM
  #40
S-Prihadi's Avatar
Dang !!! but they unlatch on their own all the time.
Old Apr 21, 2025 | 12:12 AM
  #41
S-Prihadi's Avatar
I did that when I was 18 ish year old. Ha ha ha.
I was not driving and the car has sliding rear door.
So I jumped to the rear seat , open sliding door and fire my water canon .....zooom....
Old Apr 21, 2025 | 12:21 PM
  #42
ChuangTzu's Avatar
You gotta give 'em a good push...
Old Apr 21, 2025 | 12:22 PM
  #43
ChuangTzu's Avatar
It's really not a big deal. The only time it becomes a problem is when the pilot gets distracted by handling this non-issue instead of flying the plane--typically on takeoff...
Old Apr 21, 2025 | 12:23 PM
  #44
ChuangTzu's Avatar
Was there a nice streak down the side of the vehicle afterwards?
Old Apr 22, 2025 | 11:50 AM
  #45
S-Prihadi's Avatar
Probably very little. At that age my "nozzle" is GDI pressure, close to 3,000 PSI.
If I do the same tomorrow, its Port Fuel Injector only, 75 psi max ......
Also I might fall to the road when driver brake hahahahha. My gyro not as good as when I was 18.
I did what I did is to avoid needing to overtake slow bus all over again....if pee-ing need to stop the car.
It was a winding mountain road with tea plantation.
Old Apr 22, 2025 | 08:32 PM
  #46
JettaRed's Avatar
Veteran: Army
Yeah, I skinned my "water canon" on the asphalt. Gotta be careful!
Old Apr 23, 2025 | 12:57 PM
  #47
ChuangTzu's Avatar
Old Apr 23, 2025 | 01:38 PM
  #48
rapidoxidation's Avatar
2013 ML350 Bluetec
I'd've run mine over had the car not shifted into "park".
Old Apr 23, 2025 | 02:54 PM
  #49
JettaRed's Avatar
Veteran: Army
That’s gotta hurt!
Old Apr 24, 2025 | 12:30 AM
  #50
S-Prihadi's Avatar
8 Fascinating Facts About An Elephant's Trunk! - Wildlife SOS
