Sponsored by: CARiD
Any tips on installing the propeller shaft?
Old Aug 8, 2025 | 04:58 AM
ccryan67's Avatar
2012 E350 4Matic
We are trying to install the front propeller shaft on my 2012 E350 4matic and are having trouble lining the shaft up so it can seat in the transmission. YouTube videos, that I found at least, skip over actually inserting the shaft in the transmission. My mechanic has dropped the exhaust and removed the carrier bearing, motor mounts, heat shield, and right side manifold. Significantly more than necessary and the u-joint end of the shaft still doesn’t clear the transfer case. We are doing this without a lift, and only the front end is on jacks. We are going to raise the rear end to see if that changes the angle of the transmission enough to install the shaft.
