Is this fixable (gas in diesel)
Fuel pick up is at bottom so should have been drinking diesel and no harm done in 200ft.
unless idled for a week...
Drain tank.
remove fuel line in engine bay and flush out and clean.
Examine injector pump to ensure it is not contaminated if you sense gas have it rebuilt or replaced.
Remove injectors and send them out for rebuild and clean the fuel rail lines...
check anything else fuel runs thru.
change engine oil. and then pray to Diesel gods
Drain tank.
