W212 ride height 4Matic Airmatic
I was searching a lot but I could not find the exact values.
I need to calibrate the airmatic suspension on my W212 350d Bluetec 4Matic Airmatic. I tried to find the OEM values for ride height measured from center of wheel hub to fender but I could not find.
Can someone tell me what are the exact values?
380-385-390 mm? Should all 4 sides be the same height?
I have set them all to 390mm but car looks a bit high.
Thank you.
if you need to calibrate the airmatic you must use diagnosis equipment that is able to do so .
Then you need to measure the angle of the lower control arm as specified in wis . the tool suggested by mercedes is the romess . (there are cheaper and better alternatives just ask)
The angle you measure need to be entered in the calibration sequence to get it right , then the ride Hight will correct itself automatically after the calibration process .
So, when calibrating, I should set all the wheels height to 0 mm (zero) and then measure and enter the measured angles in Xentry?
I have ordered one from Aliexpress, here is the link: LINK
Do you have another recommended tool for measuring the angles of inclination?
in my workshop i use a more proffesional tool than the one you orderd , also you will not be able to correctly position it . This is the one I'm using it's called ASAT Link it is super popular this days .
the measuring points are described in wis .
