What could this rumbling/growling sound be?
Guys,
My 2010 E350 makes a sort of rumbling/growling sound when I drive it and I’m wondering what it could be. It seems to be coming from the passengers side near the rear of the engine. It’s not exactly an exhaust leak I dont think. It seems like it could be a leak from something else but I just can’t tell what. It seems to happen more after
initial start up and I’m wondering if there could be a leak in like something that helps return warm exhaust gases into the intake manifold to help with cold starts? Of course it’s really hard to diagnose this because all the stupid engine and undercarriage coverings mean you actually can’t see the engine. Has anyone else experienced anything like this? Any tips are appreciated.
Mike
Mike
it also makes the noise if I step on the gas and brake at the same time, so when the car isn’t moving. Don’t think it’s drivetrain related.
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
Have you checked the engine mounts? When they collapse, the upper part of the mount sits directly on the lower part (no cushion between), transferring any engine vibration to the chassis.
You description sounds quite familiar.
24 GLS580 '23 E450 4matic 12 E350 4Matic
Too many options to guess, you could have someone do the brake and gas while you listen under the hood, to pinpoint the noise you can put an old paper towel tube to your ear and move it around until you find it, could be motor mounts and tranny mount as Dmatre suggests
That’s a great point. It feels like a vibration/rough running and that could definitely be it. I’ll look into it.
With the hood open give it a good gas and observe if the engine moves up on one side. If it does you need mounts.
