Gasoline E class - Direct Injection problems - resolved?
Main symptoms are clatter on start up that lasts about 20 sec.
Octane rating and whether or not a gasoline is top tier are unrelated.
I plan to use the CRC cleaner since my E400 has about 30K miles.
Have there been pics taken of MB DI engines' intake valves? Without this, it's hard to say that the issue has been resolved. Most people can't tell if their engines have decreased HP after a few years due to DI and the carboning (is that a word?) of intake valves.
Has the reduction in flashpoint in oil due to DI stopped? Have people been posting UOA's of engine oils for MB DI engines?
Without solid information, we cannot say that the issue has been resolved.
TCW-3 spec is "ashless"
Do you have a source for that important info?
People on this forum will repeat any nonsense told to them by corner mechanics, their buddies or they come up with this nonsense in their head.
Let's try this again. Which burns cleaner, alcohol or gasoline made from crude oil? Take your time....
"Two-stage engine ventilation system with rotating radial separation and downstream high-volume fine separation for optimum cleaning of the blow-by-gas"
It goes on to describe the use of a cam-driven centrifugal prefilter and fine oil particle separation chamber, though only to the effect of decreasing engine emissions and lowering oil consumption. It seems to me that this entire system is providing the effect an aftermarket oil catch can/ air-oil-separator would, something that's talked about heavily on the VW forums in TFSI threads. A few members have mentioned other makes having well documented coking issues with their DI engines, but the general consensus is that MB has found a way to mitigate it. At least delay the buildup enough to guarantee the cars are out of warranty before it happens
. I'm not savvy on whether or not the 3.5L NA 276 engines use such a system, as all the research I'd done before I bought my car was into the turbocharged engine after being burned by goopy intakes valves on previous VW's of mine. This paper also mentions, in addition to the multiple sparks per cycle, that multiple injections per cycle, up to 5, can occur. There's been plenty of debate in this thread about the validity of claims that top tier fuel is a way to save your engine from looking like crud, and while I agree that it's easy insurance against HPFP and other fuel system failures down the line, it's not going to do hardly anything to help keep your valves clean in a DI engine. But after reading about the injection method this engine uses, which I imagine WOULD carry over to the NA engines, and other thoughts about chamber and port design, would it be possible that MB uses an injection or two during each cycle while the intake valve is in it's fully open position to actually spray the valve with some fuel? This could be a factor in why we haven't heard much in the way of the NA engines gathering much crud on their valves either. Spitballing here, but just a thought.Anyway, attached document was a part of the deciding evidence that led to me buying my 18 E400 wagon, along with several other threads on this forum. First post including picture of wagon doing wagon things
very thicc twin mattress
