E-Class (W213) 2016 - 2023
Parking Pilot space detection
Old 03-22-2018, 08:28 AM
pcascio's Avatar
E-300
Thanks Rory and Tidal. I've only had the car for a few days so it's possible I'm not doing it right, but I thought I was. I'll head to the mall and try again.
Old 03-22-2018, 12:41 PM
The_Judge's Avatar
2018 E400 Coupe
Originally Posted by rorywquin
From the manual......
Parking Pilot does not assist you parking in spaces at a right angle to the direction of travel if...you forward-park....
Is that accurate? The sales representative was able to have my car forward-park in a space at a 90-degree angle to the road, but I haven't tried it. BTW, it was an agonizingly slow process! NRFPT, IMHO.
Old 03-22-2018, 01:39 PM
baobay's Avatar
2024 GLS 450 AMG Package 2024 GLC 43 AMG
I noticed the Parking Pilot works much better in the 2017 E class than in the 2017 GLS.
Old 03-22-2018, 06:43 PM
BeachBunny's Avatar
2018 E300 Luxury - P3 and more
I actually do use this feature intermittently and had good success with it.
A few notes:
1) The parking lot needs to be reasonably full for it to work. It wants to see at least 2 cars before the space, ie: [CAR] [CAR] [ ] [CAR]r. It won't bother if it sees [ ] [CAR] [ ] [CAR].
2) If the car thinks it can fit parallel into a space, it's going to try to go parallel. If it sees [CAR] [ ] [ ] [CAR] , it's going to shoehorn itself in there.
3) It uses radar & ultrasonic sensors exclusively, no cameras. So it's looking for cars, not curbs or grass strips. I've not had mine go for a curb, but it gladly parked itself in the grass median between two spaces.
4) It starts looking for spaces once you're doing 20mph or below. Slower does seem to be better for detecting spaces.
@Rory: I believe you're posting a manual for a completely different car. That looks like the way my 2015 E350 did it. My '18 E300 is completely different -- other than initially setting the car into D or R, the car handles all of the gear shifting by itself and everything is done through the infotainment system, nothing on the instrument cluster.
For my car:
The following 3 users liked this post by BeachBunny:
privee (03-26-2018), rorywquin (03-23-2018), Tidal (03-23-2018)
Old 03-22-2018, 07:04 PM
pcascio's Avatar
E-300
I think I've been avoiding full lots in order to test ride. I'll find a busier lot.
Old 03-22-2018, 10:08 PM
MercE007's Avatar
A Class
not 100% sure, but don't you need to have the indicator operating?
Yes, need to tell car to scan which side by using indicator.
It will detect space only if space is between 2 parked cars.
Old 03-22-2018, 10:11 PM
  #32
MercE007's Avatar
A Class
Yes, same happened to be me.
Old 03-23-2018, 02:32 AM
  #33
pcascio's Avatar
E-300
Thanks. I know where I'm going today.
Old 03-23-2018, 03:04 AM
  #34
rorywquin's Avatar
Shanks’s Pony
Yep it is from my '17 SL manual.
Surprises me how many people get confused about what their car can do because they have not looked at the manual.
My hard copy manuals have not even been unpacked. I have it on my laptop, phone (MB app) and, it is in the car's infotainment system.
Old 03-23-2018, 12:22 PM
  #35
Tidal's Avatar
E220d (W213)
A few notes:
i believe this is a bulk cause of the issues with the car park I was at then. I had no idea that it required more than one car and then a slot as opposed to car, slot, car, etc. Neither, despite what some would have you believe, is that written anywhere in the documentation.
Old 03-23-2018, 03:25 PM
  #36
pcascio's Avatar
E-300
Probably wants a tip too. Thanks for that tidbit.
Old 03-23-2018, 04:09 PM
  #37
BeachBunny's Avatar
Not trying to be a jerk about it, but this is the 2017+ E-Class forum... Your SL is a completely different car. Could you kindly edit the post with the instructions you posted to let people know that's for an SL and not an E-Class or remove them? The feature isn't the most intuitive to begin with, let alone false information posted about it.
jsclarke (05-02-2018)
Old 03-26-2018, 03:23 PM
  #38
privee's Avatar
2018 E class 4matic
Thanks BeachBunny for the "[CAR] [CAR] [ ] [CAR]" explanation. I have had some successes with using the system but was not sure what criteria it uses to park. Your explanation is great.
Old 05-02-2018, 12:07 AM
  #39
shadowyman's Avatar
AMG C63S, BMW M4, AMG E63S
It is unfortunate the system doesn’t work like standard bmw 4 series which asks you if you want to park perpendicular or parallel. When you choose perpendicular parking, it takes one of the cars it chose as borders of the space as reference and nicely back into next to it. I am surprised it doesn’t work that way with MB.
Old 12-01-2020, 07:19 PM
  #40
pepa1346's Avatar
w213 E300
Originally Posted by Proeliator2001
The old system only looked for parking spaces on drivers side if you indicated that direction as it defaults to passenger side. New one looks both sides at once. Mine finds spaces aplenty but I'll admit, the only time I tried to actually use it I couldn't select a space to park in; rotating dial, pushing it, tried the touchpad, nothing selected a space. My COMAND has been updated since then but I've not got round to trying it, hope it works as I used it a fair bit on the old one.
Hey, I own w213 2017 and recently faced exactly the same issue as you described.
I've just got retrofitted a digital cluster into my car and this function stopped working, it sees parking spots, but I'm not able to press "ok", I did everything, no luck.
Have you found a solution, is it working in your car now?
I'll be very thankful for your answer!
Old 12-02-2020, 03:37 AM
  #41
rorywquin's Avatar
Shanks’s Pony
Have you tried putting it into reverse?
Old 12-02-2020, 03:41 AM
  #42
rorywquin's Avatar
Shanks’s Pony
Works the same as my wife's (2015) B Class.........and my (2012) SLK before the SL and her (2010) A class before her B Class.......fairly reasonable to assume a E class would be very similar.....
Old 12-02-2020, 04:23 AM
  #43
pepa1346's Avatar
w213 E300
No, I don’t need to. The algo is simple: I run along side parking spots, car finds suitable parking spot between two cars, shows rectangle P. I select it, choose option Front or Rear and press ok. Car should put into reverse itself and start parking.
I”ve been using this system for a long time, worked very well, always predictable. But yesterday I retrofitted digital cluster and it just can’t receive my “ok” command, nothing works: steering buttons, joystick or sensor.
Old 12-02-2020, 05:37 AM
  #44
UrBusted's Avatar
Porsche Taycan, Range Rover AB, Range Rover SVR, S Class, Mclaren 570s, Urus Hybrid (soon), M3, RS6
But it's not, that's why he asked you to edit it
Where are you based? Recently the Park Pilot system was disabled in EU countries inc the UK because of some regulations which are going to come into place in 2021, quite sad we paid for an advertised feature that they won't allow us to use
Old 12-02-2020, 06:19 AM
  #45
Egonvdv's Avatar
E 300 AMG-Line diesel-Hybrid - 2021
are you sure about that ? i can't find any information about this, nor did mercedes inform me?
can't test it on my own car as my subscription expired .
Old 12-02-2020, 06:22 AM
  #46
UrBusted's Avatar
I am contacting you in response to your recent enquiry in relation to Mercedes-Benz Park Assist in your car detailed above.
Unfortunately the information is correct, at the moment this has been disabled on all vehicles which have it. The reason for this is due to a revision in EU Regulation UN R79 relating to automotive standards and safety which comes into place as of 2021.
Please see the link below, for further information:
https://eur-lex.europa.eu/legal-content/EN/TXT/?uri=CELEX:42008X0527(01)
Egonvdv (12-02-2020)
Quick Reply: Parking Pilot space detection
