Tire Warning
Received 3,747 Likes
2020 S560 Sedan, 2019 SL450, 2019 E450 Luxury Trim Wagon, '24 BMW I7 on order...
If I had been depending on Run Flat Tires, with no spare in the trunk, I would have been in the cab of the tow truck, as my car was towed off the freeway. I would have probably had to rent a car and then go through the whole hassle of getting my car back the next day.
Run flat tires or conventional tires, NOTHING beats having a spare in the trunk.
Last week in Tampa I had to wait 3 days for a pair of Michelin Pilot Sport A/S 3+ 245/45ZR18 tires. If I didn't have friends nearby to take me home, I'd have been in a hotel at a cost of several hundred dollars.
Extended mobility tires can be driven with sidewall damage. The downside to this situation is upon driving to the tire shop the tire is unrepairable.
If you live in the boonies, then finding a tire at a dealership is not easy. For me, there are 10 MB dealerships within 50 miles so tires are readily available.
Runflats can still be driven with holes in the sidewall. We had a 2 finger size hole in our BMW Goodyear 19 inch runflat and drove it 10+ miles to my dealership without a problem.
If I had to drive 100 miles then I would have had a big problem.
Several years ago I saw a demonstration wherein an inch and a half hole was created in the sidewall of an extended mobility tire.
Looking at the car one could not tell the left rear tire was totally deflated.
At the conclusion of the demonstration the car was driven away.
#32
Until you are stranded in the boonies for a few days waiting for a replacement tire. RFT or extended mobility tires won't help with sidewall damage.
#33
These RFT discussions are unbelievable. How can a luxury car manufacturer not 'vent' a component as crucial as tires. If there is anything on a car that is more critical than tires, I'd sure like to know what it is. And this is exercising due diligence??
#34
It'sl not a safety issue, it's one of convenience. So the manufactures are giving it due consideration and aren't degrading safety. In some ways they improve safety by allowing you to drive, with a flat or even damaged tyre, to a place of safety
The negative is, they consider having fitted rft, they don't then need to fit a spare wheel. I hate that and think it's crazy. The wife's car not only has a spare, it's a full sized matching alloy! Expensive and quite heavy but already been useful after she picked up a nail and slow leak
If my car didn't have different size tyres front/rear I'd be sorely tempted to carry a spare around. I do hope manufactures eventually wise up to the dislike of these tyres.
#35
#36
There is no way to determine tire brands in advance because manufacturers use several brands of tires. It is a supply issue. If you want a specific tire, put it in the sales contract. I have an order for a 2018 E300 that specifies that Good Year tires are unacceptable and if the car arrives from the factory with Good Year tires the dealer will install OEM Pirelli tires at no cost.
#37
Sorry, but this is an issue we just won't agree on. At a minimu m, MB or the dealer should disclose the type of tires to be installed on a new car before delivery and give the customer a choice. They give you alternatives on wheel size, etc. Why not tires? As it is now, it's a matter of 'take it or leave it'.
#38
Received 1,506 Likes
#39
I thought it was obvious why they and every other manufacturer does it. They do it to shave weight off the car. Every ounce/pound that they take off, increases the gas mileage by a slight amount. It just makes their CAFE numbers worse so they have to juggle the needs of the customer with the mandates by the government. There's lots of other regulations they have to meet too. Sometimes mandates by the government beat the wishes of the buyer.
I'm guessing saving weight of a spare wheel and jack, which is out of sight and out of mind (till it's needed!) is an easier sell to the public than smaller wheels.
#40
That's true to some extent but they still fit 19 inch wheels when 17 inch have less mass to accelerate and usually narrower tyres so you get better mileage. The different wheel size can push cars in the UK across business/vehicle tax bands (so 19 inch rims could cost you money every year) yet manufacturers still fit big boy wheels for kerb appeal.
#42
It is worse than we think. The bubbles apparently can form on the inner walls where you will not see them. These tires need to be redesigned or abandoned. There is no peace of mind. I am now at a dealer having two replaced at 9000 miles. A third was replaced at 3000 miles, all with routine driving in SoCal. Shame on Mercedes.
#43
Even though the idea of RFT & no spare are certainly linked, they are distinct and separate issues. If MB insists on continuing to deliver their cars with these ridiculous RFT, I can deal with that, by just switching them out. However, when they take steps to try and PREVENT owners from obtaining a spare, they have gone way too far.
Run Flat Tires are the KISS OF DEATH! No jack & spare is just plain stupid. Tell EVERY MB employee you have contact with.
#44
Those 4 gallons plus the weight of the spare are probably worth 1 MPG. That's why they do it. My guess is the E43 and E300 have approximately the same range. That 25% extra fuel is to compensate for the same percentage of less efficiency!!!!! Personally I have been surprised at the 43's fuel economy it usually gets 27 MPG highway. about 1 mpg less than my C400.
#45
Earlier this year I picked up 2 nails in the same tire within a two month period. And in both cases, my dealer replaced the tire as part of what the Service Manager called customer goodwill. They even picked up my car at my home (50 miles from the dealership) and provided loaners in both cases. My only issue was having to drive around in a not so well-equipped C300, which felt a little bit cramped in the cabin. But of course, I did not complain-
#46
My under powered E300 won't be taken on road trips. It's strictly a town car (grocery getter).
#47
You should get on your knees and thank them. Your dealer went out of his way to make you happy.
Furthermore the dealer owed you nothing, absolutely nothing. The tires are the tire company's responsibility.
#48
The comped new tire was a great gesture of goodwill on the dealer's part.
#50
I should also mention that they also had to keep my car for more than 2 weeks to troubleshoot and replace the Comand unit because it was randomly rebooting while driving. I can't speak for other areas, but premium dealerships I have dealt with in the past have similarly gone above and beyond. I think it may have something to do with the level of competition in Socal. We do have a lot of choices and dealers compete vigorously for our business. So creating long-term customer goodwill is a good business strategy. For example, an Acura dealership screwed up my servicing paperwork, which prevented me from picking up my vehicke after service department hours (previously arranged). Not only did they drop off my vehicle the next day, the manager also offered to take my family to dinner.
