E-Class (W213) 2016 - 2023
2004 E320 Radio turns on by itself
Old Apr 9, 2017 | 02:50 PM
VirginiaE320's Avatar
2004 E320 Wagon
Periodically, the Harmon Kardon radio that came with car will turn on. Car is turned off, no key in ignition. Radio not left on (not that that should matter). Drive somewhere, go inside store or arrive home and come a little later and radio will have turned on. Once it totally drained battery overnight. Any idea what can be causing this or how to fix?
Old Apr 10, 2017 | 01:40 PM
2004 E320 Wagon
Thanks. I will note that you can turn the radio on when the car is off (i.e. no key) so the radio receives power all the time. I was planning to pull the fuse tied to the radio and confirm that there is no further battery drain ... temporary fix.
How do I look into the other issue you suggest: the ignition and/or central gateway module?
Old Apr 10, 2017 | 02:09 PM
ngerstman's Avatar
2016 Audi S8 Plus/ 2011 Mercedes e550 4Matic//Gone:1985 500SEL/2000 e320 4Matic/ 2001 e55 Kleeman
You should visit the 211 forum, which is what your car is. Maybe others there have had the same issue. Regards. Ned.
Old Apr 18, 2017 | 08:18 AM
tresean1's Avatar
Veteran: Marine Corps
W212 E-class, W211 E-class, F10 5-Series
Hey VirginiaE20. Welcome to the forum...I see that you are also from VA...what part? Sorry that you have this issue, I had a similar problem with my e39 BMW in that the entire HVAC system would turn on by itself overnight and blow at full speed! Car was bat-sh** crazy.
Originally Posted by Plutoe
You are confused, a radio or any appliance must have voltage to work--when the key is out of the ignition module there is no voltage therefore the radio whether on or off will not function
Sorry, Plutoe, but you are also confused...VirginiaE320 is indeed correct, in that the radio will function with the car off and no key. They have been doing that for years, both Mercedes and non-Mercedes cars; sometimes when I am washing my car or out in the garage, I will reach in and turn on the radio to catch some tunes while I am doing a small chore---no keys or ignition required.
Old Apr 18, 2017 | 11:12 AM
RickInHouston's Avatar
2017 E400 Coupe
I've had the radio come on while driving without touching a thing. Just passed it off as one of those quirks my LEMON does.
Old Apr 18, 2017 | 12:00 PM
c4004matic's Avatar
17 E43; 21 GLS580
This indeed correct. I listen to the radio all the time with the ignition in the off position after I park. It will continue to play till you open the door or till the battery minder turns it off (20 minutes or so).
Old Apr 19, 2017 | 01:44 AM
Diesel Benz's Avatar
Even more odd that the OP's radio kept on playing until battery was flat. If it turned on, the 20 minute timer should still have saved the battery but that did not happen.
These modern head units tend to reset every now and then, some more often than others. Could be it does not remember the on/off state after a reset but if the car had been parked, the radio should not be active at all to make any resets (while driving the radio control unit is active even if the driver switches the radio off).
