E-Class (W213) 2016 - 2023
power outlet in trunk
Old Apr 11, 2017 | 12:20 PM
justinm001's Avatar
soon to be E300
There isn't any power outlet in the trunk anywhere is there? I need to keep a laptop or two for work and want to keep it on a charger in the trunk.
If no power is there a cable or somewhere i can safely use for 12V power? most likely going to put small 120V inverter and standard laptop charger in under trunk area.
Old Apr 11, 2017 | 02:08 PM
ua549's Avatar
If you can still modify your E300 order, consider adding the factory 110v option (list $110). That outlet is in the rear console area so it should be easy to extend the cable to the trunk area.
