E-Class (W213) 2016 - 2023
lowering springs for w213?
Old May 1, 2017 | 05:57 PM
Petercs17's Avatar
Anyone have any luck in finding lowering springs for the new 2017 e300? Thanks.
Old May 2, 2017 | 03:37 AM
guhvies's Avatar
2017 C43 AMG Saloon
Check out the last page of the official pic thread. vic viper has commented on this.
Old May 2, 2017 | 05:04 AM
vic viper's Avatar
S213
Might as well continue that discussion here:
There are two different H&R lowering kits available for steel suspension, they lower 30mm (on paper)
H&R-28.740.1 up to 1105kg front axle weight and
H&R-28.740.2 from 1106kg front axle weight
The latter is normally used for larger engines and 4-matic as they are heavier up front, but we usually use the lighter spring in all applications as it tends to lower a bit more.
Old May 2, 2017 | 10:46 AM
Petercs17's Avatar
thank you so much! Are you located in the us? So to make sure I should be ordering the first one you mentioned. Can you recommend a website or a shop you purchased the springs from. I'm located in the us and never purchase items outside of the us. Thanks
Old May 2, 2017 | 11:31 AM
vic viper's Avatar
S213
They are pretty new here in Europe, dont know about availability in the US, but any well sorted suspension shop or H&R dealer should be able to get them for you.
Old May 2, 2017 | 11:39 AM
ADD0514's Avatar
E300 P03
Make sure you have clear bra and be mindful of curb/speed bumps. The entire front fascia/hood is a giant rock chips magnet.
Old May 2, 2017 | 05:06 PM
Petercs17's Avatar
Thanks all. Called h&r and they told me I had to wait 4-6 weeks min. They are still awaiting approval for US. The only way is to order through 3rd party. Not sure if I want to go through the hassle with shipping.. t
Old May 2, 2017 | 05:29 PM
KOPIER's Avatar
19 E 450 wagon + 13 GL 550
Petercs17 - I was looking as well and have contacted H&R as well as Eibach - Lorinser in Newport Beach has them already tested and confirmed from Germany. They are about the same price as the H&R as well (I was surprised). I am still debating as I installed some 20" wheels and not sure if I want to worry about it. Call them and they can get you a set - most tire and rim shops can install - I would call H&R and ask them for the local recommended shops and use them to install the Lorinser springs - Good luck
Old May 2, 2017 | 08:30 PM
Petercs17's Avatar
Thank you so much. I'll give them a call.
Old May 2, 2017 | 08:55 PM
Petercs17's Avatar
[QUOTE=KOPIER;7134661]Petercs17 - I was looking as well and have contacted H&R as well as Eibach - Lorinser in Newport Beach has them already tested and confirmed from Germany. They are about the same price as the H&R as well (I was surprised). I am still debating as I installed some 20" wheels and not sure if I want to worry about it. Call them and they can get you a set - most tire and rim shops can install - I would call H&R and ask them for the local recommended shops and use them to install the Lorinser springs - Good luck
Is the shop called RTW motoring?
Old May 3, 2017 | 10:56 PM
KOPIER's Avatar
No - it's Lorinser direct - their US office is in Newport Beach and they even have a shop on site to install all of the products they sell
Old May 6, 2017 | 01:24 PM
Mbenz182's Avatar
2017 MB E300
W213 Vogtland carries them, I just ordered them from modbargains.com
