E-Class (W213) 2016 - 2023
HUD Question
Old Jun 21, 2017 | 11:20 AM
knoppe01's Avatar
2020 E350, 2019 GLC 300
HUD Question
I know that the driver can adjust the position of the display in a up/down direction. I was wondering if it is possible (by service I would guess) to adjust left/right. I would like my display moved over towards the left a little.
Old Jun 21, 2017 | 12:30 PM
c4004matic's Avatar
17 E43; 21 GLS580
The left and right positions are not adjustable. The display is very bright and visible from any possible angle you may have in the drivers position. For example, my daughter can see it perfectly when sitting on the rear passenger position. If you cant see it its probably because you are using polarized glasses.
Old Jun 21, 2017 | 12:34 PM
knoppe01's Avatar
Thanks but actually if you lean your head towards the center console the right most portion cuts out of view. I'm using the full display with SL and Nav. i'll try to play with my seating position.
