E-Class (W213) 2016 - 2023
Remove front grill??
Old Jun 26, 2017 | 09:55 AM
Done90's Avatar
Mercedes E220d 2017
Like the title says. Does anyone know how to remove the front grill on the new e class w213. Is it possible without removing the front bumper??
Old Jun 26, 2017 | 09:56 AM
vic viper's Avatar
S213
Front bumper needs to come off, but that is not very hard.
Old Jun 26, 2017 | 09:58 AM
Done90's Avatar
Mercedes E220d 2017
Vad krävs för att plocka bort fronten?
Old Jun 26, 2017 | 10:36 AM
vic viper's Avatar
S213
Jag skriver här för att underlätta för andra så får jag inte 100 PM senare
Jack up front end.
Remove front wheels.
Remove front engine compartment panelling, ~12 8mm sheet metal screws.
Remove all the front plastic covers from under the front.
This will give access to two 10mm screws holding the bumper towards the front end.
Remove left and right inner front wheel well covers, 10mm plastic nuts and plastic expander rivets, gently fold the covers and take them out.
Disconnect large bumper connector in front of right wheel, also disconnect outside temperature sensor close to that connector.
Remove two torx screws connecting the front fender to the bumper, two screws left side and two on the right.
Remove upper 5 torx screws behind front grille, remember to mark locations of these screws as this is how the distance between hood and bumper is adjusted.
Loosen the brackets where the 5 screws sat and pull entire bumper towards you.
Use a friend and gently fold the bumper outwards to clear the lights while pulling it forwards, this should make it come loose.
Grille is snapped into place with several tabs, use a flat head screwdriver to dismantle.
Old Jun 30, 2017 | 09:33 AM
Streamliner's Avatar
Geez! Sounds like my old XKE: to put in a new clutch, you had to pull the engine & trans out.
