2018 ESP Setting
So in my 2018 E300 In my individual dynamic settings, I am able to adjust Engine, Steering and ESP. Im assuming ESP is suspension related. It can be changed from comfort, sport and SPORT +. Does this lower the suspension or just make it more stiff?
Does this setting exist in the 2017 model as well? |
Originally Posted by jhpmbusa
(Post 7350781)
Does this setting exist in the 2017 model as well? This ESP option replaces the 2017 option to turn off Eco Stop/Start when you choose a dynamic setting other than Comfort (Default), which is a much more useful option, and, I suspect, a much more used option. You can still turn of Stop/Start by pressing the button, but it was easier to do both dynamic and Stop/Start in one operation. Now it takes two. Why does Mercedes make dumb decisions like this? |
Originally Posted by Cao Black
(Post 7350908)
ESP is "electronic stability program", which is essentially a computerized traction control to help prevent your car from severe under or over steering and skidding. I am not sure, but do not think that the E300 is equipped with an adjustable or variable ESP. I think the dynamic setting is a choice of On or Off. I can't imagine most people wanting to turn off ESP completely every time they change dynamic settings. We're talking about a 2+ ton, 2.0L 4-cyl sedan here.
This ESP option replaces the 2017 option to turn off Eco Stop/Start when you choose a dynamic setting other than Comfort (Default), which is a much more useful option, and, I suspect, a much more used option. You can still turn of Stop/Start by pressing the button, but it was easier to do both dynamic and Stop/Start in one operation. Now it takes two. Why does Mercedes make dumb decisions like this? The ESP setting on my 2018 is comfort, sport or Sport Plus. and it is accompanied by engine and steering, same choices here with comfort sport and sport + |
Hi, I just bought an E300 2019, and I can confirm there is a separate ESP setting. Is not just on/off is Comfort/Sport/Sport+
is not suspension or transmission related, I cannot find anything about in the the instructions manual. I will make some testing after car break in. best regards. |
The ESP settings on any of the models regulates how much oversteer/understeer the car will permit prior to engaging corrective action. In addition, it affects how much throttle cut the computer will add. In sporty driving situations, drivers may not prefer any throttle cut being engaged by the ESP, and prefer only mild corrective action in the case of extreme over/understeer. In comfort mode, priority is on driving safety - the yaw correction kicks in early to keep the car on its intended trajectory. Throttle cut also kicks in early to minimize wheel spin and the possibility of loss of control. For *most* drivers, comfort should be the right setting. If you like to push the tail out a little, you'll need Sport/+ or off as your configuration.
