E-Class (W213) 2016 - 2023
Automatic Parking
Old Mar 5, 2018 | 09:33 PM
jhpmbusa's Avatar
2021 M550i
Automatic Parking
Recently, for the first time I tried the automatic parking feature. Towards the end it will tell you to step on the brakes. My questions is, if I don't stop the car myself will it run right into the curb?? If the vehicle normally brakes on its own to avoid an accident, why would it run straight into the curb when parking?
Has anyone tried not braking till the end?
Old Mar 5, 2018 | 10:40 PM
makris0000's Avatar
I have but only for a few seconds after it finished. I noticed it does not move, but I have only left it for a few seconds. It will ding the first time, then it will ding a second time.
I am not sure what it will do after that because I do not want to risk curbing a rim.
Old Mar 8, 2018 | 02:29 PM
Diesel Benz's Avatar
Avoiding an accident and hitting curbs while automatic parking are completely different features. Having said that, the answer was interesting because I've never tried the feature at all (wife's car and I hardly drive it, my V222 has a less sophisticated parking assist and I never use it).
Old Mar 8, 2018 | 06:10 PM
jhpmbusa's Avatar
2021 M550i
if you are in a parking space and you place the gear in reverse, and there is a car passing by, the car will press the brakes for you and will not allow you to reverse. that being said, whats the difference between a curb behind you.... automatic parking would be nicer if it was fully automatic and place you in park afterwards.
It can calculate the distance from every angle. why not stop it for you as well. you can even pick if you want the car to park heads in or rear.for you.
Old Mar 9, 2018 | 09:45 AM
makris0000's Avatar
You could just open the drivers door which automatically puts it in park.
Old Mar 9, 2018 | 11:06 AM
baobay's Avatar
2024 GLS 450 AMG Package 2024 GLC 43 AMG
My E300 goes into P after park assist is finished.
Old Mar 10, 2018 | 01:37 AM
I didn't say it does not brake or that it would be unreasonable to expect that. I just said that the two features are completely different. Pre-Safe features mostly work on longer range radars and front stereo camera while automatic parking works mostly with short range ultrasound distance sensors.
I also said I have not even tried it and have not read the manual but reading other replies, I interpret that the car does what you expected it to do (as far as possible although I'm sure not all curbs are easy to detect accurately).
Old Mar 10, 2018 | 07:00 AM
jester1's Avatar
2017 mercedes GLE 43 coupe
The parking feature should only have the car work the steering.The gas pedal & braking remain up to the driver.
Old Mar 12, 2018 | 03:28 PM
BeachBunny's Avatar
2018 E300 Luxury - P3 and more
At least in my 2018 E300, all of those functions, steering, brakes, throttle, are all handled by the car. I use it quite often actually and it does stop automatically. If you have the 360 camera setup, when the Parktronic system is doing its thing, you'll see a small set of red horizontal lines on the tire paths. This indicates where the car is planning on stopping. I always to have my foot hovering over the brake pedal when using the system, and sometimes will even drag the brake a bit to slow it down, but so far it's always gotten it right.... BUT, ultimately, it's my car and if something goes wrong, it's my **** on the line, so I use it, but I don't trust it implicitly.
Old Mar 12, 2018 | 05:51 PM
jhpmbusa's Avatar
2021 M550i
hmmm wonder if its your p3 that stops it at the end? scared to try it haha!
