E-Class (W213) 2016 - 2023
Spacers on 2017 e300
Old Apr 15, 2018 | 07:28 PM
Mieh100's Avatar
2017 e300
I have a 2017 e300 with the 19inch Amg wheels . The wheels sit in a bit too much under the fender and was wondering if anyone has added spacers and what size for the front and back are ideal . I am sure it will add a much nicer stand .
Old Apr 16, 2018 | 12:50 AM
vic viper's Avatar
S213
5mm is max if you want to use stock lug bolts and still take advantage of the centering hub.
Old Apr 16, 2018 | 05:20 AM
Mieh100's Avatar
2017 e300
I was thinking 5mm front 10mm back .
Old Apr 16, 2018 | 05:24 AM
vic viper's Avatar
S213
10 rear will work but you need a custom spacer with an extended hub carrier, otherwise you will not be able to centre the wheel properly
You also need longer lug bolts..
Old Apr 16, 2018 | 05:40 AM
Mieh100's Avatar
2017 e300
https://www.amazon.com/Mercedes-Staggered-Wheel-Spacers-Centric/dp/B079B6L8R5/ref=sr_1_fkmr2_2?ie=UTF8&qid=1523871531&sr=8-2-fkmr2&keywords=10mm+spacer+2017+e300
what about these ?
Old Apr 16, 2018 | 03:23 PM
Mieh100's Avatar
2017 e300
Would 15mm be too much on the rear wheels ?
Old Oct 28, 2018 | 02:13 PM
SpaceDesign's Avatar
2017 E220 Estate & 2012 E200 Saloon
Hi all, how did things pan out for any of you on the spacers? Curious to see how they look, and if the ride was effected?
