Changing Brake Pads
Changing Brake Pads
Just wondering if anyone here have changed out brakes pads on this w213 yet. I think mine are due with 24,xxx miles. I have changed the pads on my w211 and wondering if these are similar.
Thank you
Thank you
![Arrow](https://mbworld.org/forums/images/icons/icon2.gif)
Just started researching pad replacement. Google service menu W213, in the WORKSHOP menu you'll see BRAKE PAD REPLACEMENT, pressing OK will retract the calipers, (you'll will hear them retracting).
I have NOT found out if I should turn off the ignition completely to continue the work, it makes sense that I should.
Next you'll find option to return calipers to normal position and to exit service menu. These are just quick pointers, there are some videos on YouTube.
On my old W211 I used to pull the plug on the brake servo, before working on the brakes.
I'm trying to find more complete instructions, and will post unless someone has them first.
John
