pirelli run flat tires?
whats everyone's feedback on these? has anyone switched them out for a non run flat tire, im wondering since i've got the lowered amg suspension on 19 inch tires. would a regular all season tire provide a plusher ride?
The Pirellis are excellent all around tires. Not the ultimate tire in any particular parameter but still excellent all around. As runflats they are a little harsh on broken pavement but that's it. They are quiet, handle great and offer an excellent comfort/ performance compromise. You can only see any king of grip limitation on true racing conditions. For the road you will never get to its limits. When mine wear out I will probably replace them with the new michelin pilot supersports only because I do occasionally track the car and those are even grippier.
I have Pirelli Cinturato P7's in 245x45/18 run flats on my E300 (town car) as specified in my order contract. My BMW (highway car) has Michelin Pilot Sport A/S 3+ in the same size but non run flats. The Michelins wear out very fast. I got 5k miles on a set that was replaced by Michelin at no cost. The current set will be worn out by 20k miles. I won't buy Michelin tires again even though I've used them without issue for 50 years. They don't build them like they used to.
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
I have Pirelli Cinturato P7's in 245x45/18 run flats on my E300 (town car) as specified in my order contract. My BMW (highway car) has Michelin Pilot Sport A/S 3+ in the same size but non run flats. The Michelins wear out very fast. I got 5k miles on a set that was replaced by Michelin at no cost. The current set will be worn out by 20k miles. I won't buy Michelin tires again even though I've used them without issue for 50 years. They don't build them like they used to. ![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
2021 E450, 2020 C43, 2015 C300, 2007 C280
Michelin Premier A/S's on C300 (W205)
Just yesterday I replaced my 17" Pirelli run-flats with 17" Michelin Premier A/S's on my C300 (W205). (The car in my Signature below is my first Mercedes, a 2007 C280 (W203).) The new tires seem slightly better on the few rough surfaces and tar strips I have encountered in the last 24 hours.on C300 (W205) There was one double-track railroad crossing that is rough enough to cause me to slow down below 30 mph. That seemed smoother. Turn-in, a feeling of more direct steering contact, is substantially better. (The Pirellis's were really numb.)
Bear in mind that 17" tires have full sidewall height, so I have not shared the bitterness about the ride of run-flats that I have encountered in the W205 forums. I have not had any broken or bent wheels either. This is at least partly, because the Pirelli's (and a couple other models of so-called run-flat tires) are technically not run-flats. These "run-flat lite" tires are designated "Mercedes Original Extended" ("MOExtended" or "MOE"). According to Tire Rack, "However, since they don't meet all of the International Organization for Standardization (ISO) run-flat tire operating limits under all permitted vehicle loads, they cannot be branded as run-flat tires. ... [Mercedes has] collaborated with several tire manufacturers to develop lighter-duty temporary extended mobility tires that [enhance] vehicle fuel economy and everyday ride comfort." Tire Tech: Mercedes-Benz Original Extended Tires (MOExtended or MOE) So I did not expect the new tires to make a great difference.
PSS do have a short life, its a factor of their adhesion. 5k sounds a little short unles they got raced or alignment was off. In my hands they usually lasted about 12-15k. The new version 4+ are rated the same as the OEM Pzero that came with my e43 (300). Michelin claims 20% longer life.
Runflat Tires
Please see my blog in the W213 E class regarding Runflat tires. If you’re getting a hard ride from your Runflat tires you could try the solution that worked for me. Inflation them to the maximum inflation pressure on the fuel filler door, doing so smoothed out the ride for me on my 2018 E300-4matic.
Doc
Doc
Agreed
Doc
Doc
Agreed. It improved the ride for me too. Not to mention optimizing throttle response, tire wear, and gas mileage. Ride improves all the way up to 40 psi, front and back. (That's what my gas flap sticker says too! However, my misaligned gas flap had to be replaced, and maybe the dealer replaced it with an AMG part.) It has worked on other cars of mine too. I suspect that the tires absorb less energy and pass more energy to the suspension, which is better able to deal with it. Help me out, you real engineers.
UPDATE on the new Michelin Premier A/S's that I described in my post of 6/19/18: I finally got to drive on my most hated local road. It is a narrow, winding, slightly hilly road that has been patched so endlessly that it is scheduled to be completely repaved later this summer. Where it is not patched, heavy trucks have pushed the asphalt into waves. The difference is not dramatic, but now I don't have to slow down when my wife is with me. The vibration over patched surfaces like this is now more like a distant rumble. Best of all, I can now feel the road! Steering inputs are instant, and, perhaps because of less vibration from the broken surfaces, I can feel steering pressure changes from the road back up through the steering. Before these tires, I considered my C300 to be a family sedan, not a sport sedan. I liked TRAVELING in it, but did not enjoy DRIVING it. Now I enjoy DRIVING it! I guess that is a dramatic difference, after all. (I don't know where the underling of random words comes from. I can't fix it.)
Doc
Doc
gfmohn (06-24-2018)
