Music doesn't mute when NAV announcements made, even in fade mode.
So far, a no go for me.
Ok, other than ticking off the automatic volume in sound, this is the only adjustment I see for audio fade out. I've ticked it of and on with no success at all.
I've tried Haag suggestion of going into the dealer menu, but couldn't get in following his instructions. I may end up going to the dealer over this one.
The forum talks about a bug in the software that can be solved as follows:
- enter the dealer menu (pushing down the controller for 10 seconds in the main car-menu)
- select 1 - Volume Seperation
- select 1 - Navigation Guidance
- change settings to desired value (0= no mute, 24 = max.mute)
- press back key
- select "END" at the bottom
Be aware, I have not done this myself. I have just copied and translated it from the German forum. But maybe it works for you.
I checked the dealer menu and the settings are all default min-max zero. The nav separation values are all 9.
