E-Class (W213) 2016 - 2023
Music Play Order in Mercedes COMAND
Old Jan 17, 2019 | 06:51 PM
grossmsj's Avatar
2018 E400 4Matic
Originally Posted by MBpippo
From what I've read about Gracenote in the COMAND manual, Gracenote is only used to identity CDs put in the CD slot of your car - according to my version of COMAND. The Gracenote database is on the hard drive of your car and is updated in conjunction with navigation maps update performed by the MB dealer. The idea being that your COMAND display will show album art, track name, artist, etc, as this info is not contained on the actual CD.
We seem to have crossed paths somewhere over the Pacific Ocean!
Old Jan 18, 2019 | 10:21 AM
Egonvdv's Avatar
EQE SUV AMG-line 350+
as grossmsj mentioned we have swapped copies of our exile albums,
but in his car they don't play in right order and in mine they do.
so all points indeed to the system, not the files itself
the only good thing about all this is that we get to spin Exile; possibly the best rock album ever made!
Old Jan 18, 2019 | 10:50 AM
nycebo's Avatar
2021 Mercedes Benz e450 Wagon
What version of Comand are you using, Egonvdv? I'll check my own tonight.
By the way, I wonder if the reason for the issue is a hidden field inside the tracknumber that makes it look like '1/10'. The slash probably causes the Mercedes Comand to read the number as text instead of an integer. There more on it here:
https://community.mp3tag.de/t/flac-d...number/13822/3
"Note that MP3Tag will only show you the TRACKNUMBER field via the internal %track% value, since the above mapping makes it impossible to use %tracknumber% anymore. That value will return only the track number portion of the data, and if you're only using MP3Tag to view your FLAC tags, you'd never know any better.
However using a tool that actually shows the accurate tag name and values will reveal that your TRACKNUMBER tags actually contain the full track#/totaltracks string as is part of the ID3 spec for TRCK."
Old Jan 18, 2019 | 12:02 PM
Egonvdv's Avatar
V 03.76.00.10
they updated from 00.61.01.00. which also played the music in the right order
Old Jan 18, 2019 | 12:05 PM
grossmsj's Avatar
2018 E400 4Matic
Originally Posted by Egonvdv
V 03.76.00.10
How do you check this?
Old Jan 18, 2019 | 01:13 PM
Egonvdv's Avatar
go to the main menu & then to the car (symbol)
then press & hold
Old Jan 18, 2019 | 06:45 PM
  #32
MBpippo's Avatar
2013 C204 C250 Coupe
Originally Posted by grossmsj
For the record, do you know if you have Gracenote on your system?
Sure do...
Old Jan 18, 2019 | 09:50 PM
  #33
MBpippo's Avatar
Hahaha, yes!
Old Nov 9, 2019 | 01:46 AM
  #34
E300de's Avatar
E300de
I just received my E300de estate (2019) and have my music library in FLAC on USB and have the same problem as described in this thread. The sort order of tracks in albums is alphabetical.
I ended up using https://picard.musicbrainz.org/ to
- replace artist with albumartist
- add track number as prefix to title
- add year as prefix to album name
It really is a great tool to manage your FLAC music library. Here is the tagger script I used:
https://picard.musicbrainz.org/docs/scripting/
$set(artist,%albumartist%)
$set(title,$num(%tracknumber%,2) - %title%)
$set(album,%originalyear% - %album%)
Now albums and tracks are in correct order in my car. Sometimes the track number is displayed twice because the COMAND interface shows track number in FLAC file next to title (that is already prefixed with track number) but so be it...
Old May 2, 2023 | 05:59 AM
  #35
Zdenek's Avatar
W204
Hello
Spoiler
