I don’t like the key fob.
Say you've been outdoors for a few hours on a sunny day, and your car sits at the far end of a parking lot, now very warm inside. If you wanted to open the windows and moon roof, and activate seat ventilation as you approach the car, is there an easy way to do that other than using the fob?
(My car is approaching the NY port, then on to the west coast in another month.)
I think the fob is slippery but will stay in my pocket most of the time. Covering it up is ok to keep scratches from happening, but you also won’t ever see the scratchless fob because it is....
Covered
2019 E450 4Matic & 2018 E400 4Matic
Wait, we can activate seat ventilation with the fob? Which button does this?
Covered
Mercedes Benz e450 Wagon / Porsche 911 Cabriolet
CaptainE raises a good point. My hands are generally very dry in the winter in the northeast and the key is very slippery. Many is the time that it slid out of my hands and skid across the floor. For my part, the cover is more about a grippy cover than covering the fob. But the OCD in me likes the scratch protection nevertheless (despite 1 or 2 scratches on the corner already existing).
#32
#33
Page 79 of the operator's manual says that if you press and hold the SmartKey unlock button, it will unlock the car, open the side windows and sunroof, and switch on ventilation of the driver's seat.
#34
That's a great option for sure. I'm thinking mainly about times when I'm walking back to car with a camera in hand, and just need a little fresh air to flow through and suck out the heat. Easier then to reach into a pocket and press the SmartKey than to take out my iPhone. Talk about first-world problems, eh? :-D
#35
2019 Dune Silver Metallic E-450 Mercedes Cabriolet NEW Mercedes 2020 GLC300 graphite gray SUV
#38
Alternative might be to rip that page out of the manual and burn it.
#39
Lensjack - Stand close to the driver's door and point the keyfob directly at the driver's door handle while pressing and holding the unlock button.
lensjack (01-24-2019)
#40
Best mercedes keyfob design ever. it's about time they change the design. I just carry the fob only. The slick (soap) design easily slip right in my pocket and never have to use it until i get home and pull it out. I have no ring on the key, I just stick it to my magnet on my home key holder.
#41
UPDATE: I tried this a couple times today in different locations, and could not make it work. No windows opened. Sunroof did not open. When it comes to learning about this car, I'm still drinking from a firehose. Some key factoid may have blown right past me. I'll research this further as time permits.
lensjack (01-25-2019)
#43
My experience with a lot of device covers, for phones and such, especially soft plastic devices- ones that get used and pocketed often- are that lint, grit and such get under the cover. And then the cover just helps keep it in there- slowly grinding into the smooth shiny plastic, creating little tiny scratches with every step you take, every time you touch or move the key. Every. Day. All. Day. Sand, grit, scratching, marring, dulling.
But, with a cover! now worries- outta sight outta mind right?
#44
Perhps jL100086, but these fob covers are very very very snug. It would be very difficult for anything to get under the cover. If dust can scratch the fob, they are too easily scratched to begin with. Another advantage as far as I'm concerned is the fob is now grippy with a silicone cover, whereas without one, they are really slippery little buggers.
#46
Here's how it worked for me: The first long press (aimed at driver's side door handle) unlocked the doors. The second long press (similarly aimed) opened the windows and sunroof, and turned on seat ventilation. All while standing close enough to the car to touch the door handle. Haven't yet tried it from a distance. But this at least beats a kick in the fruit stand. Thanks again.
#47
#48
'21 E63S4S in glorious Brilliant Blue Magno
Seriously, Silverlight?
#49
Did hand wash my car today. The soap seems to depress the freezing point a bit, as it's right at 32 outside. Reparking in the sun took care of it to finish the wash. Drying & warming up in front of the fire now. It's going to snow again mid week. But at least a few days of sparkle.
& I just purchased one of the covers, as my original complaint- the fob is too slippery for me. No Longer!
#50
Thank you validating my OCD card is up to date with the rules contained in the manual!!!
