Higher sidewall on 19 inch rims
Hi
With AMG line the fron wheels are 245/40/19 and the rears are 275/35/19. For winter tyres I have looked at tyres with the dimensions 245/45/19 and 275/40/19, sidewall factor increase of 5, instead because the price difference is dramatic and I would prefer a tyre that fills the well more. Will it rub? Does anyone have first hand experience with slightly bigger wheels?
Hi
By my calculations it will be off around 4% from factory and the overall height of each wheel will increase about one inch (2.45 cm front and 2.75 cm rear). I have seen lowered w213 but I assume they use coilovers or air suspension, which I wont have.
I swapped out the rear tires on my old 2009 CLK550. I went from 255/50/18 one size up to a 265/50/18. After I did, the traction control light would blink when I went around corners - it was especially bothersome when driving thru the canyons. The small difference in diameter was enough for the car to think it was loosing traction when cornering. I'd stick with the same diameter tire.....
The tire diameter, rolling radius or revs per mile must be as closely matched to the original specs as possible. The actual wheel size isn't a concern as much as offsets and clearances. IMO the best sources of data to use for comparisons is TireRack.com and Wheel-Size.com.
OP, you can easy run taller tires, maybe not as tall as you want, but you'll have zero issues with 255/40-19 with 285/35-19 (but not on stock wheel - too narrow) or maybe even 235/45-19 with 265/40-19.
There is a big (actually huge) typo here. (Probably meant 255/35-18.)
JDPEClassUK (02-01-2019)
The latter option, 235/45-19 front and 265/40-19 rear might be a good option. The tyrewall is slightly taller but as I understand smaller variances are ok. These are slightly narrower than the summer tires mounted on the 19 inch factory rims, but will they fit anyway? I am very new to buying winter tyres as I bought my last car with a winter set included.
More importantly for winter (I missed "winter") you want a square set up (over staggered) and definitely going down to 18", and for 18" the tallest would be 235/50-18 (with plenty of snow tire choices) - both satisfies your requirements: (much) taller sidewall and narrower tires which is very beneficial for snow/ice.
235/45-19 & 265/40-19 was a hypothetical rather than practical exercise since do not think anyone actually makes them as a set.
The concept was that the aspect ratio stayed numerically the same and I merely increased the width one size (10 mm) and that bump and the resulting new aspect ratio was enough to cause the traction control system to be unhappy - was the important take away, as this was real world experience. Hence the point to keep the same diameter.
For winter it is alway advantageous to go -1 and narrower than stock with higher sidewall, hence 235/50-18 (since you're on 19s, even stock size of 245/45-18 will satisfy your requirements) on 18x8 (or 18x8.5) square set up. If you are in the US, TireRack has some fantastic pricing.
mercedes.fan (02-01-2019)
Absolutely not, as long as both front and rear are in sync. (Speedo error is only relevant if one is on a legal speeding border line and 2 m/h is a decider in getting a speeding ticket or not.) Regarding concerns wether a car will have any issues with front & rear diameters increased of up to 1" inch, then the answer is no (as long as tires fit without rubbing).
Im thinking to go 245 45 19 and 275 45 19 in the rear. Stock tire sizes 245 45 18. Any possible issues?
I don't think I will have rubbing issues as the car is not lowered
if you then take a 275(27.5 cm) wide tire and make the profile the same(45) then you end up with a side wall height = 45% of 27.5 cm = 12.375 cm
so your tirewall will be over 10% bigger
so besides it looking “hot-rod” it will only help ride smoothness on the rear. And if you have 4matic - this is a big no no as wheel diameter should be identical on all four wheels.
the correct way to go about this is to lower the profile if you want a wider tire... that way you can keep the tirewall height close to identical.
my tires are:
front : 245/35-20
rear: 275/30-20
if your stock is 245/45-18
your best bet on 19” would be
front 245/40-19
rear 275/35-19
and make sure you have a wider rim with an offset to match
rgds Jake
