changing brake fluid?
Hello guys!
I'm looking into doing service b on my 2017 e300 W213 RWD myself. I basically got everything except exchanging the brake fluid..
I have read over DIY brake fluid change post for W211 but not sure how much fluid I will need for my car and I also found two part numbers on mboemparts for the brake fluids so I'm not sure which one I should get? I am assuming last two numbers are for the different sizes?
https://www.mboemparts.com/oem-parts...IFJlc3VsdHM%3D
Anyone have the Daimler instruction manual for the changing brake fluid for my car model that can share, or know how much and which one(one of the links) I should buy I would be greatly appreciated!
thank you guys in advance!
Workshops use a brake fluid pressure vessel to replace the brake fluid and with this device it is very fast and easy.
If you are doing it manually it will require two people and a lot more time.
1 litre should be enough, but get an extra bottle just in case.
dejasxt (03-07-2019)
dejasxt (03-20-2019)
Received 1,491 Likes
For the repair manual, you would get a copy of the WIS which you can either pay about $6.50 for a knock off copy on eBay, or pay $60 for 24 hour access to MB's Startek system and download as much as you can in that time period. The knock off copy also includes EPC which is the electronics parts look up and lets you find parts for your car based on the VIN. If you just do Star Tek, EPC access is separate and they charge $75 for one year access. At least for $75 you get live up to date info. The knock off copy will just have the data as of the current date of the database that you get.
https://www.ebay.com/itm/Latest-2018...n/123679649919
https://www.startekinfo.com/StarTek/subscribe.jsp
https://epc.startekinfo.com/epc/subscribe.jsp
