E-Class (W213) 2016 - 2023
cannot load contacts from cell
Old May 22, 2019 | 02:17 PM
hshachter's Avatar
2018 E300
All of a sudden my contacts cannot be loaded from cell phone. Was working fine until today. Cell is Pixel 2 running latest version of Android.
Old May 22, 2019 | 07:52 PM
rbrylaw's Avatar
2019 E450 4Matic & 2018 E400 4Matic
Reboot your Pixel phone and it will likely load your contacts when it comes back up.
Old May 23, 2019 | 10:38 AM
hshachter's Avatar
2018 E300
Been there, done that, still no good. Doesn't show previous calls either. Also tried unpairing and repairing, but that did not work either.
Old May 23, 2019 | 10:48 AM
rbrylaw's Avatar
Then you should reach out to Google for assistance. Anytime my contacts haven't loaded from my iPhone Xs Max, a simple reboot solved it.
Old May 23, 2019 | 12:22 PM
ua549's Avatar
Do the other phone functions work through COMAND such as text notifications, voice phone calls (incoming & outgoing), ...
Old May 28, 2019 | 12:26 AM
hshachter's Avatar
2018 E300
Problem Solved
It was my phone, not the MB. I found that Contact permissions were turned off in my Bluetooth settings for the Mercedes connection. How it got changed is a mystery, but once I allowed Contacts to be shared, they appeared in the phone app.
Old Oct 2, 2019 | 04:37 AM
Egonvdv's Avatar
EQE SUV AMG-line 350+
Have same problem with my iPhone 8
contacts load (only) til the letter S
already:
deleted / reconnected phone
hard reboot comand
checked settings under Bluetooth profile
Any ideas / solutions?
Old Oct 19, 2019 | 09:31 AM
Egonvdv's Avatar
anyone have any tips?
I reconnected the phone several times.
sometimes I let the car find the phone, and sometimes the phone the car.
but each time the contacts get loaded till T (t before it was S...)
command is on latest versqion & so is my phone...
Old Oct 20, 2019 | 07:07 PM
mikefamig's Avatar
2005 R230 SL-500 / 2017 E300
i had the same problem a while back and don't remember the exact procedure to fix it but it involved un-pairing the phone and then pairing it again.
Mike.
Old Oct 28, 2019 | 08:08 AM
Egonvdv's Avatar
i did that several times already , even with a 24hr wait period inbetween...
Old Nov 19, 2019 | 08:41 AM
Egonvdv's Avatar
My car is at the dealer ...again
they gave me a 1 year old E class as a loaner and this car does the same thing with my contacts
so i guess the problem is on the phone's end…?????
Old Nov 20, 2019 | 09:41 AM
Egonvdv's Avatar
seems indeed it's an iPhone issiue (ios 13)
i found this at our "neighbours" : https://www.bimmerfest.com/forums/sh...9#post13166459
Old Nov 21, 2019 | 02:36 PM
JDPEClassUK's Avatar
E Class Estate S213
Try going to bluetooth menu in phone, find the car listed and then the ‘i’ next to it. Ensure the slider for contacts is green. Often this gets reset after phone software update.
Old Nov 22, 2019 | 02:57 AM
Egonvdv's Avatar
this is done...
Old Jan 16, 2020 | 07:52 PM
CynCarvin32's Avatar
Mercedes Benz
Have you found a solution? I have the same issue with my 2018 GLC and just had the NTG software updated without success.
I am running ios 13.3 currently.
Old Jan 17, 2020 | 08:26 AM
Egonvdv's Avatar
it resolved itself. no idea how….
try to delete & reconnect:
delete both in car & under bluetooth in phone.
then do hard reboot of phone & comand,
then reconnect
Old Jan 17, 2020 | 08:28 AM
mikefamig's Avatar
I ended up taking the car to the dealer and they got it to work. I don't remember exactly what they did but what I do remember is that they un-paired the phone from the car after loading the contacts and then re-connected the phone and that worked.
Mike.
Old Feb 17, 2020 | 03:22 AM
zibby43's Avatar
'20 GLC300 SUV
I figured out a fix.
Go to Settings, Bluetooth, then click the “i” icon by proper MB connection listing.
Make sure “all contacts” is the only group with a check mark (no recents, no other groups).
Then go to the COMAND telephone settings. Go into contacts. De-select “sync contacts automatically.” Instead, do a manual sync from the COMAND.
All contacts should then sync. Afterward, you can re-select the automatic sync option on the COMAND.
Voila.
(Obviously you have to be in the car with a BT connection to complete these steps).
