Tire pressure sticker vs. warning display
In the warning one tire is 40 psi and is marked OK.
The other 3 tires are 36, 37, and 39 psi and marked low.
The sticker in the fuel door states tire pressure should be 33 psi.
Tires are 245/40R19 on AMG wheels.
How do I find out what the correct pressure is?
Thanks in advance,
D.
I use the suggested air pressure on the fuel flap plus 10%.
So if the suggested pressure is 33 psi., when cold I keep the pressure at 36 psi. I find the ride the same as at 33 psi, but I get better fuel economy.
You do not state where you live: But here in the NYC area in the fall and winter the pressure will drop due to the cold and I have to "top off" the pressure and bring it back up to 36 psi.
Thanks in advance,
D.
