E-Class (W213) 2016 - 2023
Weather Display
Old Jul 16, 2019 | 12:43 PM
SalTex's Avatar
2019 E450
Weather Display
I've searched thru the manual and the forum but can't find any help so maybe someone here can assist. My 212 came with sirius weather and I used it often for forecast and radar. My 450 says it can display weather, has a way to turn it on in the navigation settings, but I still just see the normal nav map. What am I missing? Or is the same type of map not available anymore?
Old Jul 16, 2019 | 03:37 PM
arnsbrae's Avatar
Weekend: 2010 SL 350 r230 Weekdays: 2018 E220d Coupe
You have to zoom out quite far on the map to see the weather...
Old Jul 16, 2019 | 06:49 PM
TPAbnz's Avatar
2017 E300W
Perhaps a different service, I find it under "Mercedes Apps". Besides the weather maps, there is access to local interstate cameras for local traffic. Good luck!
Old Jul 17, 2019 | 02:47 AM
joshg1001's Avatar
2017 E300
The map will show severe weather, not a general forecast unless you go into the Mercedes Apps. The severe weather will show up as a triangle on the road, and if you have navigation routing currently on, will announce to you that you are approaching the severe weather. If you are not under routing, you have to go into the positioning map menu and drag the cursor to the triangle to see what its showing.
