New (to me) E300 and Question re Folding Mirrors
I have verified this via the Service Assistant and Service Manager at my dealership, and another dealership. They do not keep keys in their dealer inventory for the same reason.
As you observe, enterprising car thiefs now use electronic devices to detect smart keys 1) outside a parked car, but 2) still within range of the car. Just enter car and use the device as a relay, press keyless go and they are gone without the key present (because the key is within range and still communicating with the car). If the smart key were deactivated via the accelerometer, then the key would not be detectible, and could NOT be used to start the car. This confirms that the key remains active unless it is taken out of range and allowed to sit still, then power down.
The logic within the key (or car system) assumes (first, by default) that a key within range is there to be used to start the car, so it remains active. Take it out of range, then the secondary shutdown logic takes over. Makes perfect sense.
Someone posted this surveillance cam video of a relay device theft of a Keyless GO MB in action in the UK.
NOTE: The MB is a current model E or C... Looks like a W213 to me.
The thief is at the garage door scanning for the (still active) key, and finds one, because it is still within range of the car and alive, even though the key is sitting perfectly still. As you suggest, the accelerometer should have turned the key off, but hasn't, because the car is still within range and maintains a handshake with the car.
If the key were truly powered off (stored further away in the house where the accelerometer would then work), then the cretin would not have detected the key. So much for accelerometers saving the day...
This has all been verified by Konigstiger in previous discussions,
like this one... https://mbworld.org/forums/e-class-w...y-warning.html
Or this one on this forum....https://mbworld.org/forums/e-class-w...e-vehicle.html
And another...https://mbworld.org/forums/e-class-w...ss-remote.html
I assume that left folded, they will come back out by themselves when the car is started? (Couldn't do that at the dealer - it was inside.)
I have learned that the key does not send a signal constantly but the car "wakes" the key by sending a signal to the key as soon as you touch the door handles (or start button).
But again, maybe the European and US-verions of the keys are not the same.
Just double click the lock button and wait for the red LED lighting up for approx a second, the key is now deactivated.
the key with you and lock the vehicle." I wonder why?
If you are replacing your key battery more often than once a year, then you have a true (objective) indication whether your key "goes to sleep"... or not when inside the vehicle.
Here's another experiment. Store the second fob well out of range, and it will go to sleep. When the key battery stored inside the car dies, you will have plenty of time to acquire a fresh battery while driving the car on the remotely stored fob for several months after.
https://www.mbusa.com/content/dam/mb...n_Operator.pdf
Think twice before suggesting that AMG Smart Keys are different from regular E-Class Smart Keys. They are not. The AMG owner's manual doesn't even have a reference to Smart Keys. None at all.
If you are replacing your key battery more often than once a year, then you have a true -- objective -- indication whether your key "goes to sleep"... or not when inside the vehicle. Store the second fob well out of range, and it will go to sleep. When the key battery stored inside the car dies, you will have plenty of time to acquire a fresh battery while driving the car on the remotely stored fob for several months after.
Unused key: 3.0321 V
Used key: 3.0298 C
After 8 months, the key that is used every day and resides in the car has drained the battery to the extent of reducing its open-circuit voltage by 2.3 millivolts more than the key that has sat in a drawer, untouched. Typically, a CR2032 would not need replacement until its open-circuit voltage drops to 2.7 V. In other words, the key that spends its night in the car and the key that spends its night in the drawer are essentially identical with respect to their useful lives after 8 months.
