Alignment check
E350e. W221 S350CDI
Alignment check
Alignment check... I know that you can only adjust the toe in on the E350e. I知 told that you have a choice to set the toe in in either comfort or sports mode. I am unsure how to do this.If you stop the car when you are in comfort mode will that be OK? Basically I知 not sure if the ride height stays the same when you turn it off and get out. Can someone please tell me what the recommended toe in is. I understand front and rear are the same.
tks...BTW I live in Thailand
