E-Class (W213) 2016 - 2023
Galloping Wipers
Old Jan 27, 2020 | 03:55 PM
rraisley's Avatar
2020 MB E450 Estate, 2019 Kia Niro Touring
Galloping Wipers
Okay, not quite galloping, but during lighter rain, my wipers hop the last third of the way across the windshield. It happened to me 3.5 weeks ago, when driving the new car from the dealer's to home, and happens now. So everything should be relatively "clean". I've heard about waxing windshields (ceramic or otherwise), etc. but what should I do to settle my wipers down to a nice wipe. They are, after all, WIPERS, not HOPPERS. ;-)
Old Jan 27, 2020 | 06:14 PM
E300-18's Avatar
2018 E-300 4matic Sedan
My car did that when it was new. Over time, it got better for some reason. Oddly enough, I had a loaner for my recent service that only had about 1500 miles on it, and it did the same thing.
The dealer claimed to have replaced the wipers once to attempt to fix it, but it didn't matter. The only way I could make it temporarily stop was to spray some washer fluid. I could also swear it got better when I refilled the washer fluid with plain cheap Meijers brand.
I don't buy into the idea that I need some sort of special care process for my windshield. IMO, it the wipers are relatively new, they should just work.
Someone posted the following link on this forum for Bosch wipers. If they have them for your vehicle, it might be worth a shot.
https://www.partsgeek.com/gbproducts...-08058260.html
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
Happens to me all the time - even after the dealer replaced my blades.
Try using the windshield washer. I use "plain jane" windshield washer fluid which helps.
Other times the wipers work perfectly.
I have not figured out why they work and why they do not work.
One of Life's great mysteries!
Old Jan 27, 2020 | 06:17 PM
JDPEClassUK's Avatar
E Class Estate S213
Wipe a little tyre wall gel on the blades and they will be super smooth and clean better than ever.
Old Jan 27, 2020 | 06:34 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
This is an issue that plagues pretty much every new Benz and has for many years. I've yet to find a fix.. tried everything from adjusting angle of the arms, all different blades, dealer cleaned windshield with OEM cleaner, claybar windshield, polish.. nothing has ever solved it. It's ridiculous.
Old Jan 28, 2020 | 08:00 AM
ua549's Avatar
Over the years I've never encountered any issues with the wipers. I never run the wipers over a dry windshield. I manually clean the glass to remove insect remains and other debris.
Old Jan 28, 2020 | 09:56 PM
rwells4's Avatar
(currently) 2025 AMG CLE 53 Obsidian(formerly) 2022 CLS450 4Matic Diamond White on Black leather
I'd have the dealer check the wiper arms to make sure they haven't loosened. Did you recently have the windshield replaced, by chance? Might not be the same thing I'm thinking, but mine did this - kind of a jerking motion that eventually caused one arm to just stop working (while driving, in the rain - fortunately passenger side). Dealer took care of it.
Old Jan 28, 2020 | 10:11 PM
rraisley's Avatar
As I said in my original post, the car is less than a month old, and the hopping started on the drive home from the dealership (80 miles away). The car, and the windshield, will probably never be cleaner.
