pothole/TPMS
Yesterday, I drove over a pothole at about 45 MPH. Right after the tire pressure graphic shows up (on the instrument cluster) with the numbers in 3 corners in red and little x's next to them and the tire pressure warning light comes on. I scroll over to Service and then to Tires to see the same graphic with the tire pressures and 3 x's. I scroll down and it asks me "Use Current Pressures as New Reference Values?" I accept and it says "Tire Press. Monitor Restarted" and the tire pressure warning light goes out. The tire graphic with the same 3 little x's and red numbers show up again, I redo what I just did and and then it all goes away. I drove for maybe 5 miles after and it did not come up.
Has this happened to you? I'm wondering if driving over the pothole just jiggled the TPMS tech and it needed rebooting or has something broken and I should take the car in to have it checked out?
Thanks! Stay safe!
