E-Class (W213) 2016 - 2023
DPF and diesel duel cleaning products
Old Mar 22, 2020 | 07:56 AM
Kostas Velaetis's Avatar
W238
I wonder if its ok to use these products from Wurth (https://www.tzambaolla.gr/index.php?...roduct_id=2160) . Can anyone suggest me a good product to maintance my engine and DPF filter without damage my car? thanks
Old Mar 23, 2020 | 01:42 PM
Jan AMG's Avatar
The best or nothing
Use BG products. They are proven and work well.
Old Mar 28, 2020 | 06:36 PM
mobster600's Avatar
e300
There is nothing you can do to maintain a DPF. If and when it gets coated with exhaust soot, it needs to be baked at like 600 degrees to remove the stuff. There is no chemical additive to prevent that.
As far as some injector cleaner, it’s all garbage. The 213 motors are direct injection, which are high pressure. Your computer will let you know when they are not at the correct pressure.
Dont put ANYTHING in your car unless your dealer does it.
I believe my dealer put a fuel additive in once, I didn’t question it. As it’s on the record they did it not me.
Stay away from additives
