Recirculation Doesn't Stay On
Bottom line from the Nanny owners is that this 'feature' will save your life and or keep your windshield from fogging up. The same people probably want self driving cars (dodo heads imho).
Sometimes when I am sitting in traffic, I want to limit the exhaust intskefintake other cars and push the "recirculation" button. But after a while, it goes off on its own.
I've a 2017 Porsche Panamera 4S and there is a haptic switch on the center console and if you push it, then the recirculation remains in recirculation. Plus it has a switch on the overhead console that will eliminate the sound/noise if you get too close to your garage door (that happens each and every time. NOT too close at all). Two good examples of cars not being Nanny cars. Tesla is beyond hope and should be scuttled.......if I didn't have a bunch of it I bought on March 17th.
What car today has it I wanna check out their website?
Never owned a Lexus....
After a little bit of internet searching seems to be only a LExus feature
OTH, I hear you about what a PITA the fires are on all kinds of levels. Such large, continuous amounts of smoke particulate is a very low probability event, and understandablly something not presently a design criteria given the above considerations. Sort of a situation where one cannot look at their their cake and eat it at the same time. Maybe Mercedes will read this thread and change their firmware to allow an override on the recirculation button.
There is a dry paper filter on the air inlet under the hood and a second, thick, high quality particulate filter in the air pathway. If you have allergies, I believe there are slightly more expensive, special active carbon filters available from MANN or other German OEM suppliers. This could be changed every 3-6 months instead of recommended 12 month interval. Continuous fire smoke excepted, this would be a better solution considering the car A/C system and your respiratory system together. Also, might it be a good idea to learn how to change that passenger footwell large filter, certainly once the smoke is subsided, if not evert couple weeks during??? In heavy smoke areas it would not be a case of over-kill, that is for sure.
As an aside, I habitually turn off the A/C and set the fan to high when I am within 2-3 km any destination anytime the car will be sitting for more than a few hours, especially in a small garage. This purges the evaporator air box of condensation and dries out the internals. There is often a substantial amount of liquid water blown out via the drain holes using this technique, especially if the ambient humidity is high to begin with. Prevents any musty smells from developing over the period of ownership.
Genesis is another brand that has this: https://genesisowners.com/genesis-fo...l-system.2949/
Porsche seems to have it too: https://www.macanforum.com/threads/a...ulation.72322/
I didn't search for every brand, but a simple google search for ["brand" automatic air recirculation smog] gave me those results
