Checking tire pressur
From the cluster i click on services then tire pressure, other people it gives them the image of car with 4 digits in my case it display this message
*runflat indicator is active press ok to restart" i restart it couple of times but still it doesn't show any tires pressure at all.
"runflat indicator" will only be activated when there is a lose of pressure and will not show how much pressure is left. This is a standard option called "Tyre pressure sensor"
While the additional option is called "Tyre pressure monitoring sensor"
Why I am concern about it, because I am planning to replace my run flat tires with non run flat, and I prefer to always see the pressure of the tires.
when the tire deflates, it starts turning faster, which he system picks up
the "tire pressure monitor system" has sensors on the valves, so it's a completely different system
there are aftermarket solutions - see this link ( just as an example, no idea if this one is any good)
Amazon.com: Tymate Tire Pressure Monitoring System-Solar Charge, 5 Alarm Modes, Auto Backlight & Smart LCD Display, Auto Sleep Mode, with 4 External Tpms Sensor (0-87 PSI): Automotive
The car is imported from canada, so this seems correct. Did you find any solution for this feature?
I'd personally like to know what would be required to upgrade. Sensors, and perhaps additional coding?
