E-Class (W213) 2016 - 2023
Trickle chargers and the new 3.0 48V system...
Old Mar 19, 2025 | 07:40 AM
  #51
W205C43PFL's Avatar
Pure gas is hard to come by depending on where you live nowadays, the fuel stabilizer too is a good suggestion.
Old Mar 19, 2025 | 07:47 AM
  #52
L1Wolf's Avatar
Veteran: Army
W214 E450
not sure why but it helps in my experience so that's that.
It's hard to prove a negative, but how do you know it helps? Could it be that if you did nothing that you would not gotten flat spots either? Logic is that even with increased pressure there is still a part of the tire that flattens due to the weight of the car. It's just a smaller spot at best. Taking weight off completely eliminates that. Over inflating could cause other problems, but it's hard to speculate.
Old Mar 19, 2025 | 07:50 AM
  #53
L1Wolf's Avatar
Veteran: Army
W214 E450
In TN, it's not hard at all. I do agree that it's hard to find in some areas though. If you can get it, then it's a good idea to use it if the car will sit for months. It's also good to fill the tank to reduce condensation regardless of the gas.
Old Mar 19, 2025 | 07:59 AM
  #54
W205C43PFL's Avatar
When I don't do it, I will surely get those vibrations until after an hour or even hours of driving if the vehicle was sat for 3 months. When I do it, the vibration only lasts for like 15 minutes after taking out of storage, again just my experience, not the norm.
Old Mar 19, 2025 | 08:01 AM
  #55
W205C43PFL's Avatar
Yes for sure, fill up the tank to the maximum before storage. When we think of fuel stabilizer, we think of usages such as marine equipment and lawn mowers, snow blowers, I think that was what it was intended before. Or maybe... perhaps it was also intended for classic vehicles and garage queens.
Old Mar 19, 2025 | 08:03 AM
  #56
W205C43PFL's Avatar
Don't get me wrong, I do agree with eliminating the weight altogether but some don't have the luxury.
Edit: I have a two door garage and the side is full, I do nkt have any room to put a jack under the vehicle up and put jack stands. Maybe only the other side but I don't that is good for the suspension. I do agree jacking up is the best choice.
Old Mar 19, 2025 | 08:06 AM
  #57
W205C43PFL's Avatar
I always wonder why dealerships I come across overinflate their tires up to sidewall maximum pressures when sitting on the lot, it is not just MB, most car brands does the same thing, and especially true if it has to sit through months on a vessel. So maybe perhaps there is some truth to it on preventing flat spots? I mean, I have anecdotal experience but it doesn't really mean much to anyone else
  #58
L1Wolf's Avatar
Veteran: Army
W214 E450
Interesting. I've never heard that before. Certainly suggests that increasing pressure helps, but also that it doesn't totally eliminate the issue. With it going away in a relatively short time suggests no permanent damage to the steel belts, but it having this happen over and over could cause a premature failure of a belt.
Old Mar 19, 2025 | 08:09 AM
  #59
W205C43PFL's Avatar
not denying that at all.
Old Mar 19, 2025 | 08:13 AM
  #60
W205C43PFL's Avatar
Perhaps I should just get these next time https://www.homedepot.com/product/ra...ers/1000821217
Old Mar 19, 2025 | 10:29 AM
  #61
wildta's Avatar
GLE 580
Um, reason why I linked it because I was curious, not because I disagree with you, matter of fact, overinflating to prevent flat spotting was something I've been doing all the time and works well in my experience. This doesn't say why you shouldn't just says you should not with no explanation. So up for debate.
I run Michelin tires so I'm going to try their suggestion on my next long trip. I imagine, worst case I will get some vibration that works itself out after a few hours of driving.
Old Mar 19, 2025 | 11:26 AM
  #62
W205C43PFL's Avatar
I see, if you want, you could also get those flat stoppers at homedepot.
Old Mar 19, 2025 | 11:27 AM
  #63
W205C43PFL's Avatar
Just realized the homedepot link is broken, here just use this: https://www.raceramps.com/car-storag.../flatstoppers/
I am not sure if these are effective though.
Old Mar 19, 2025 | 03:19 PM
  #64
L1Wolf's Avatar
Veteran: Army
W214 E450
Those look like they would work. Much easier snd safer than lifting the car on stands.
Old Mar 19, 2025 | 04:49 PM
  #65
W205C43PFL's Avatar
I guess I will give it a shot next time I travel.
Old Mar 19, 2025 | 05:05 PM
  #66
ua549's Avatar
My neighbor uses something similar for his BMW while he is in Rhode Island for 7 months each year. He has not had any flat spot issues.
Old Mar 19, 2025 | 05:37 PM
  #67
W205C43PFL's Avatar
Perfect, sounds like we found the solution then.
