E-Class (W213) 2016 - 2023
Active Blind Spot and Lane Keep Inoperative
Old May 22, 2021 | 12:29 AM
orioles128's Avatar
W213 E63s
Hi all,
I am getting the following codes C110800 Radar Sensor 8 Malfunction and C1101FA left rear radar sensor 1 Malfunction on a 2018 E class wagon. Does anyone know where radar sensor 8 is located?
Old May 22, 2021 | 11:00 AM
konigstiger's Avatar
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
File Type: pdf
Old May 23, 2021 | 12:43 AM
orioles128's Avatar
W213 E63s
Per the diagram, it appears there are only two radar sensors each located at the rear corners.
Old May 23, 2021 | 02:46 PM
'71 Pinto
If using Xentry should give explanation if not using Xentry I believe C110800 Radar Sensor 8 is rear left sensor communication error I would suggest visually inspecting sensors/connectors for corrosion. Post VIN I will confirm # of rear sensors.
Old May 23, 2021 | 04:23 PM
orioles128's Avatar
W213 E63s
thank you so much. The vin is WDDZH8KB7JA361627
Old May 24, 2021 | 10:46 AM
'71 Pinto
Two radar sensors & six unrelated parking system sensors. Visually inspect both radar sensors/connections if replacement needed both sensors are part # 0009059907.
File Type: pdf
Old Jun 1, 2021 | 12:12 AM
orioles128's Avatar
W213 E63s
Thanks for all the help. The dealer fixed it under warranty.
