E-Class (W213) 2016 - 2023
E Class VIN Decode
Old Feb 27, 2022 | 07:29 PM
  #226
vinnybenz's Avatar
2013 GLK350 2016 GLE400 2019 E450 Wagon 2018 S560 2021 E450 AT
Some may be able to use this link to get your VIN data card and save Konig some time. It worked for me.
https://mb.vin/
Old Feb 27, 2022 | 08:00 PM
  #227
ADebelius's Avatar
E63S
https://mb.vin/
Thanks a bunch! That worked.
Old Mar 7, 2022 | 04:07 PM
  #228
g0deaterzx's Avatar
E220d
Could someone please decode my VIN please? None of the decoding websites i've gone to could recognise it.
My VIN is W1K2130042A838027
thank you!
Old Mar 8, 2022 | 12:57 AM
  #229
cranjeeet's Avatar
2020 E350 4Matic
CAN YOU PLEASE DECODE MY WIN :W1KZF8EB0LA807654 . APPRECIATE YOUR HELP IN ADVANCE
Old Mar 8, 2022 | 09:56 AM
  #230
konigstiger's Avatar
'71 Pinto
Originally Posted by g0deaterzx
None of the decoding websites i've gone to could recognize it. W1K2130042A838027
Attached.
File Type: pdf
Old Mar 8, 2022 | 09:58 AM
  #231
'71 Pinto
Originally Posted by cranjeeet
CAN YOU PLEASE DECODE W1KZF8EB0LA807654
Attached.
File Type: pdf
Old Mar 8, 2022 | 12:50 PM
  #232
Alan Smithee's Avatar
Just got the VIN for my March build S213...hopefully everything is there that should be. Can you bring up W1KZH6AB2NB057899?
Old Mar 8, 2022 | 01:45 PM
  #233
'71 Pinto
Attached.
File Type: pdf
Old Mar 8, 2022 | 02:03 PM
  #234
You're awesome, konigstiger. Thank you.
Old Mar 8, 2022 | 06:32 PM
  #235
punchlist's Avatar
2020 SL550 2022 E450 sedan 2018 silverado
Would you decode W1KZF5KB4NB050340
Thanks John
Old Mar 9, 2022 | 10:04 AM
  #236
'71 Pinto
Attached.
File Type: pdf
Old Apr 9, 2022 | 12:31 PM
  #237
I've got another one for you, if you don't mind: W1KVK8AB4NF003203
Old Apr 9, 2022 | 03:19 PM
  #238
'71 Pinto
Invalid.
Old Apr 9, 2022 | 08:29 PM
  #239
Perhaps a bit premature...the car is supposed to be built next week.
Old Apr 22, 2022 | 01:24 PM
  #240
kaileybutt's Avatar
2015 E400W4
@konigstiger - and any others who may be able to shed some light
WDDHF6HB2FB087106 - recently acquired and concerned the black ash trim (2A70) is suffering from the same fading as the burled walnut. The TSB addresses the burled walnut but I can find no reference to black ash trim suffering the same fate.
Any input would be greatly appreciated
thanks in advance
File Type: pdf
Old Apr 22, 2022 | 01:36 PM
  #241
cetialpha5's Avatar
thanks in advance
Faded wood was only covered under the 4 year factory warranty, not under CPO. You can tell if you open the door and look at the wood hidden by the door vs the exposed wood trim. As your car is a 2015, it would be well out of factory warranty. You can try getting the dealer to cover it with goodwill, but I doubt that will happen. The wood trim kits alone were over 3k list at the dealer, even online it was 2k. Sometimes you find used kits on eBay but the wood could still fade later.
Old Apr 22, 2022 | 02:53 PM
  #242
kaileybutt's Avatar
2015 E400W4
10-4 thanks cetialpha5 - I presume the flawed UV coating was on all wood trims vs just burled walnut - burled walnut probably being the most prevalent - best info I have come up with is the 'clean' dates didn't begin til 2016 and later - some of the ebay offereings show manufacture dates way earlier - is there any definitive bulletin on a clean date? Appreciate your reply.
Old Apr 22, 2022 | 03:14 PM
  #243
cetialpha5's Avatar
I don't know of any but someone else might know more. There are many stories on here about their wood getting replaced and then fading again a few years later. I suppose it's easy for MB to get away with it because their parts warranty is only 2 years.
Old Apr 22, 2022 | 04:35 PM
  #244
Invalid.
Hi konigstiger - Would you mind trying that one again?
Old Apr 22, 2022 | 05:46 PM
  #245
'71 Pinto
Old Apr 22, 2022 | 07:58 PM
  #246
Interesting...OK, thank you for checking again nonetheless!
Old Apr 24, 2022 | 01:34 AM
  #247
malik1337's Avatar
e450
Hey I’ve just imported an e450 from the states, can you help me decode the vin?
W1KZF6JB9LA773000
Old Apr 25, 2022 | 11:28 AM
  #248
'71 Pinto
Attached.
File Type: pdf
Old Apr 27, 2022 | 02:48 PM
  #249
Bo Zhang's Avatar
E63 Wagon
Would appreciate the data card for below VIN, thanks a ton!
W1KZH8KB4MB003996
Old Apr 27, 2022 | 03:27 PM
  #250
'71 Pinto
Attached.
File Type: pdf
