E-Class (W213) 2016 - 2023
Left steering wheel buttons not working
Old Aug 13, 2021 | 01:56 AM
Thatboymarcuss's Avatar
W203
My left steering wheel buttons aren’t working. They light up but none of them are working. Anyone know of a way to reset it like you would the comand if not, anyone know about how much the stealership will charge to replace the part? T.I.A
Old Aug 13, 2021 | 10:13 AM
Elvisfan0108's Avatar
2021 c300 Cab. Arrived 7/28/21 . 24 GLE 450e.
There is no way of knowing if a part needs to be replaced. Prices vary by region. It could just be a loose wire. You could try contacting a dealer or a repair shop in your area.
Old Aug 13, 2021 | 10:46 AM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
Maybe use this to reference the connection if you are willing to take apart your wheel to look
Old Aug 13, 2021 | 01:26 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
First step should always be scan for codes... don't have a scanner, buy one. Doesn't need further elaboration. Now while you wait for your scanner, disconnect the main battery for 10 minutes. That'll reset the modules. If you're still waiting for the scanner to arrive, you could check the wiring between the switch and the steering control module.
