E-Class (W213) 2016 - 2023
Kick plate fallen off
Old Sep 23, 2021 | 01:36 PM
jreaveley's Avatar
E220d
Hi,
What I think is called the kick plate, i.e. the metallic plate that says 'Mercedes Benz' on it on the door sill, has fallen off on my car leaving a plastic version exposed underneath. I can't tell how it was supposed to be fixed - there's no sign of any failed glue or similar, does anybody know please? I'm wondering if I could glue it back on again or if I have to order a new one (~£30 I believe).
Thanks in advance for any advice anybody has.
Old Sep 23, 2021 | 03:28 PM
konigstiger's Avatar
'71 Pinto
Looks like the part separated, cover came off base. Part in its entirety is mounted with double sided tape. I would suggest gluing cover back in place. If you choose to replace I believe part # is 2056800035, need VIN to confirm.
Old Sep 26, 2021 | 11:11 AM
martinlarose's Avatar
2025 e 450
Originally Posted by jreaveley
Hi,
same thing happened to my wagon. I took it to the dealer after i had called them as i am 200 miles away from it and they did replace it under warranty...
Old Sep 27, 2021 | 11:35 AM
jreaveley's Avatar
E220d
Thank you for the responses. The dealer here claims it's not covered by my (extended) warranty. I have now glued it in place - it seems OK, so fingers crossed it stays in place. If anybody ever does the same, be very careful with the glue - the plate is on a slope and the glue was runnier than I had anticipated so I nearly got glue all over the door frame!.
Old Nov 30, 2023 | 05:07 AM
SR92's Avatar
E class 200d
I ran into a similar situation today. What glue did you use? Did it last long?
Old Nov 30, 2023 | 06:55 AM
jreaveley's Avatar
E220d
I used bog standard superglue and it's still attached.
