E-Class (W213) 2016 - 2023
Recall Article: Fire Hazard
Old Jan 6, 2022 | 08:46 PM
TennesseeZ4's Avatar
2019 E450 wagon: 2019 BMW 430i: 2013 Chevy Traverse: (departed)2013 SL550 & 2019 E450 cab
Two questions: 1) has anyone received a letter from MB for this issue? 2) has anyone discussed this with their dealer?
See article from CNN Business: https://www.cnn.com/2022/01/05/busin...3IRehAvrAxHMyg
Thanks.
Old Jan 6, 2022 | 08:55 PM
W205C43PFL's Avatar
This issue is posted across the forums already but hopefully you are not affected, the key things to note would be:
1. Only affecting diesels, mainly OM654 or OM656 produced between January 2017 to October 2021.
2. MBUSA vehicles are not affected by the recall.
Old Jan 7, 2022 | 10:20 AM
Most excellent news! Thank you!
Old Jan 7, 2022 | 10:26 AM
W205C43PFL's Avatar
You are most welcome, enjoy your vehicle!
Old Jan 7, 2022 | 01:25 PM
Sudden's Avatar
E300 de T 2021
For us affected, fire hazard due to leaking water pump? Anyone know how this even possible? Electricity involved?
Old Jan 7, 2022 | 03:13 PM
Diesel Benz's Avatar
Very little information about the issue. The coolant pump is volume controlled by an electronic actuator that controls vacuum and vacuum controls the coolant pump. The explanation was that coolant leaks to the vacuum and may cause fire.
Does not make it any more sensible to me.
