W213 Head up display height
I have P3 package with head up display. Is there a way to adjust the height of the display - it falls way too low, and I have adjusted its "position" to the max possible within the settings screen. However, I find it still lower. I don't want to increase the seat height though just to see this!!
2021 e All Terrain, 2001 e55
you use the left had side of the steering wheel touch pad, swipe up on the Nav page. when you are on the heads up edit view swipe to the right and you will see a gear image from there you can move up or down or right or left. I am doing this from memory so forgive me if I am off but if you play around you will figure it out
There are no other settings that I am aware of. I suggest checking out another one to see if it’s the same. Maybe something slipped.
