Thoughts on fuel additive 000-989-61-06-09
Now there can be a need for a fuel system "cleaner". I had one car with some big miles on it that I fed a steady diet of Shell V-Power. Good gasoline. The techs at the dealer used Shell V-Power. Then the Shell station raised its prices. But a nearby Chevron station (and Exxon) station did not. At some point I filled up the car's gas tank with Chevron Supreme with Techron. Before the tank of gas consumed I noticed the engine running better. I talked to the techs about this and they told me that while they will use Shell gasoline they'll fill up the fuel tank once in a while with Chevron for the benefit of Techron. Or they will add Techron to the fuel tank.
(My SA told me while the techs could get Brand X fuel system cleaner -- the same stuff that was added to my car's fuel tank at oil/filter service time -- at an employee discount when he walked through the service area every tech's tool box has a bottle of Techron on its top. For Techron they had to buy this at a retail store.)
Might add I had two cars. Both car engines received a steady diet of Shell. Then both were fueled with mostly Chevron gasoline. One engine as I noted above reacted favorably to Chevron gasoline. The other engine didn't object but didn't complain, so to speak, either.
The one that reacted had "big" miles. Engine ran good. Didn't use oil. But it has big miles. (200K+) The engine was naturally aspirated. And last but not least it was fitted with narrow band O2 sensors. The one that didn't react had around half as many miles and was turbo charged (from the factory) and the engine was fitted with wide band O2 sensors. Wide band O2 sensors provide for more precise fueling. I assumed then the engine even with Shell gasoline just ran cleaner and there were no engine deposits for Techron to remove.
If a Chevron station not convenient you can add a bottle of Techron to the fuel tank. The advice I received was to do this a few hundred miles before an oil change was scheduled. Techron can increase oil contamination. One way because it is designed to *not* burn but in the heat of the combustion chamber turn into a vapor then when this vapor contacts colder surfaces it reverts back to a liquid and in doing so this provides some engine deposit removal. But some Techron liquid can end up in the oil.
If you don't want to use Techron, there's an organic way to cleanse the engine. I have found that just a long drive -- ~50 miles at freeway speed -- can apparently remove engine deposits. After such a run the engine is running better. Not lots but noticeably better to be sure. The prolonged steady state running gives whatever brand of gasoline is being used a chance to remove engine deposits.
I guess the bean counters at MB think us folks in the US have no taste for style and removed the chrome because we’re too stupid to notice. It may sound like a small thing but when you’re spending about $65k with some options as in any business, it’s sometimes the small things that count.
