E-Class (W213) 2016 - 2023
Recommended aftermarket scissor jack??
Old Dec 14, 2022 | 01:30 PM
ddcha's Avatar
2022 E53 SG
Just looking for one that is compatible with our jacking points. Modernspare has a kit but the scissor jack is only rated for 1.5 tons.
Old Dec 14, 2022 | 01:36 PM
Alan Smithee's Avatar
1.5 tons should be OK...you are only lifting part of the car...
MB OEM jack part number is B6685079128.
Old Dec 14, 2022 | 01:52 PM
ddcha's Avatar
2022 E53 SG
appreciate the quick response. That oem part appears to be sold out everywhere.
Old Dec 14, 2022 | 02:06 PM
DFWdude's Avatar
2016 E350 Sport
I would invest in a 4 ton bottle jack before I bought a scissor jack... Just as compact , but less difficult to use. Amazon has dozens to choose from.
Use a hockey puck for the jacking point if you think it necessary.
Old Dec 14, 2022 | 02:53 PM
Long Islander's Avatar
2018 E400 4matic Wagon
Instead of a bottle jack or scissor jack, I would get a floor jack (a/k/a trolley jack). I've used a floor jack for years on several different cars and I've been happy with it. You can get one for as little as $40. I have a ProLift floor jack that came with a case which is handy for storage.
Old Dec 14, 2022 | 02:59 PM
I found this one on Amazon for $47:
Amazon Amazon
Old Dec 14, 2022 | 03:29 PM
ddcha's Avatar
2022 E53 SG
I found this one on Amazon for $47: https://www.amazon.com/dp/B01FJ4TI40...NrPXRydWU&th=1
appreciate the suggestion and research but i already have a floor jack in my garage. It’s so heavy! I just want something for emergency use after having a bad experience this weekend. I will already be compromising trunk space with a donut spare. I just want a light scissor jack i can mount to the inside of the spare and be done.
Old Dec 14, 2022 | 04:12 PM
DFWdude's Avatar
2016 E350 Sport
If someone wants a scissors jack, I presume it's for emergency use only. At home under controlled conditions, I would never use a scissors jack, but a floor jack. All of this has been clarified by OP.
Originally Posted by ddcha
I appreciate the suggestion and research but i already have a floor jack in my garage. It’s so heavy! I just want something for emergency use after having a bad experience this weekend. I will already be compromising trunk space with a donut spare. I just want a light scissor jack i can mount to the inside of the spare and be done.
For emergency use on the highway, I would still use a bottle jack over a scissors jack any day of the week. And they make some bottle jacks no larger than a scissors jack that would easily fit within the spare wheel.
In truth, you would want to make sure that a bottle jack was the largest possible (that fits from ground to jack point) but still fits stored within the spare wheel. JMO.
Old Dec 14, 2022 | 04:38 PM
Bahnstormer's Avatar
2010 E63 AMG, 2003 E500
I bought a scissor jack for emergency purposes with oversized feet for added stability.
Old Dec 15, 2022 | 08:12 AM
ddcha's Avatar
2022 E53 SG
Appreciate everyone’s input. I decided to go with the modern spare kit after talking to the engineer who helped design the kit for the W213. Price is a bit high but seems to have a high quality tested product. Canceled my ez-spare and switched to modern spare as well. 32lb vs 51lb and higher speed rated tires made me switch to them.
