E-Class (W213) 2016 - 2023
Headlight trouble
Old Feb 20, 2023 | 03:55 AM
Edgardo Aguilar's Avatar
2017 e300 4matic
Headlight trouble
2017 E300
last Friday I replaced my right side headlight and module due to water damage. A buddy of mines owns a shop and sold me a used headlight that came with a used module for a good price. He cleaned the pigtail, cleared all the “ Inoperable low beam, high beam, ect” messages and to my surprise the headlight worked . Worked for a few days then I was driving it last night and everything was good till this morning when I started it up I seen my light is off
again and I have about 6 messages saying “right” side lamp features inoperable.I removed the bumper and the headlight and plugged it in on the left side and the headlight came on and it works good so it’s not the headlight itself. Maybe a wire? Pigtail messed up on right side ? So I bought a new pigtail cover and cleaned the wires then plugged it back on the right side but it still didn’t work. Anyone have any idea what it could be? How come it works on the Left side but not the right? It seems as if there’s no power on the right side. Really bummed since it hasn’t even been a week since I
fixed it. Is not receiving power? Could it be due to it being a used module? a bad wire? A fuse? Programming/ Coding?
I don’t have the splash shield/ fender liner that’s how I got water damage in the first place but I haven’t drove on water since I fixed it.
Old Feb 20, 2023 | 06:00 AM
The G Man's Avatar
2019 E300
Sound like your previous water damage is not 100% fixed yet. You might have a bad or wet connection somewhere.
Old Feb 20, 2023 | 10:25 AM
konigstiger's Avatar
'71 Pinto
Next step, initial startup see attachment.
File Type: pdf
Old Feb 21, 2023 | 08:12 AM
e55phil's Avatar
2021 e All Terrain, 2001 e55
I hit a deer and damaged my front end. MB replaced the headlight but the old one worked so I kept it. My car is a 2021, i do not know if it will fit your car but if it will you can PM me
Old Feb 21, 2023 | 03:46 PM
2017 e300 4matic
Just came back from the shop they said it was just a burnt fuse, they replaced for free and now the light is back on. They said nothing is wrong with the wires or headlamp but if it happens again then most likely it’s the Used Control module burning up the fuse Which would result in me needing a new one.
thank you for your responses
Old Sep 29, 2024 | 07:27 AM
marek19959's Avatar
Hi
i have same problem, with my head light i have replaced new head light, and it doesn’t light up, do u know location of the fuse its also right side same as urs, thanks
thank you for your responses[/QUOTE]
Spoiler
