E-Class (W213) 2016 - 2023
All Terrain Rear Wiper Washer Delay S213
Old Apr 2, 2023 | 03:31 PM
E430_4MATIC's Avatar
1973 280SEL 4.5; 2021 E450S4 Wagon
When activating the rear washer, the fluid doesn't spray until after 1 1/2 wiper sweeps across the dirty, gritty glass.
I seem to recall the water sprayed first in my s212.
Anyone know the order of events in the A/T? I'm wondering if there's a faulty check valve causing the fluid to delay.
Thanks!
Old Apr 5, 2023 | 08:06 PM
W205C43PFL's Avatar
Thanks!
I am guessing it takes time to bring the fluid up, what windshield washer fluid do you use? I wonder if that plays a role in the delay as well, I seen it pretty common on the E-Class with or without magic vision. I am not saying it is normal or not but it is common for the front. Since you specifically mentioned the rear wipers, it might be due to the same issue.
Old Apr 6, 2023 | 07:16 AM
I use Mercedes-Benz Winter Fit diluted as it calls for.
I thought there should be either a check valve and/or delay before the wiper sweeps after the fluid is sprayed.
Old Apr 6, 2023 | 10:23 AM
W205C43PFL's Avatar
It also depends on how frequent you use the washer function and so if the fluid has already fell back to the reservoir. I am not aware of a check valve and/or delay but there might be.
